Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 06-11-2008, 01:08 PM
74toyotafj 74toyotafj is offline
87 Towing
Hello does anyone know the towing capacity of a 87 chevy suburban v20 with 5.7 and 4.10's?
Thanks
Old 06-12-2008, 08:20 PM
Re: 87 Towing
bump anybody?
Old 06-13-2008, 09:04 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 87 Towing
Mechanical condition and frame rust and trailer hitch is the first thing to check.
If in good shape they will pull there heart out.
MT
MT
Old 06-13-2008, 03:30 PM
Re: 87 Towing
It is completly restored with no rust and motor,tranny,tcase,axles have 32k on them!
I'm just looking for a number because I am planning to tow a 2k trailer with my 4800pound landcruiser from ct to pa and back roughly 300 miles one way.
Dont want to overdo the burb
Old 06-13-2008, 04:44 PM
MT-2500's Avatar
AF - Advisor
Re: 87 Towing
Sorry I do not have the numbers.
You might look in owners manual for towing specs.
But I see no problems.
Just make sure you cooling system is clean and good and the rad is big enought and good.
And change coolant if it has 3 yers or more on it.
A good big extra tansmission coller is best for towing.
And give the transmission a pan drop and new filter and dexron fluid.
Good Luck
MT
You sholld be set to go.
MT
Old 06-13-2008, 07:42 PM
Re: 87 Towing
I wish I had the manual The radiator is a brand new hd aluminum unit along with a new tranny cooler(replaced old one) I was planning on changing tranny fluid tcase gear lube and front and rear end gear lube plus plugs engine oil cap and rotor and air filter.
I guess do that and hope for the best thanks
