Old 06-11-2008, 12:52 PM
sjr8ut sjr8ut is offline
all of the sudden no reverse!
Hey guys,
I have a buddy with a 94 subaru impreza with an automatic trans. He came out a bank, started his car, tried to put it in reverse but it was a no go. Nothing--as if he was in neutral--the engine just revs when he pushes on the gas. He got the car towed, and now the forward gears work but still no reverse. The car has 145k miles.
Anybody have any clue what this could be? The mechanic didn't even look at it but just said it needs a new tranny to the tune of $2000. Could this be a fluid/filter problem? (the fluids are topped off)
Thanks.
Old 06-12-2008, 03:00 PM
maxwedge maxwedge is offline
A990 racer
Re: all of the sudden no reverse!
Most likely this is internal assuming the linkage is adjusted, not damaged or nothing hit the the trans pan and did damage, the fluid and filter change will not correct this.
Old 06-13-2008, 03:19 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
Tell your friend he's putting it in neutral..
Just kidding..
Seatbelts Saved My Life
Old 06-13-2008, 03:55 PM
Hungrycat7's Avatar
Hungrycat7 Hungrycat7 is offline
Who needs reverse anyway? Nothing a little push can't solve!
Old 06-14-2008, 02:12 AM
72chevelleOhio 72chevelleOhio is offline
Don't know about this car, but a lot of newer transmissions have pressure switches and harness' to go bad. They can cause it not to apply a "gear" or apply two "gears" at once. (Burning up the trans in the process)
Older transmissions can be low on fluid and reverse is the first to go. (or have a plugged filter)
Either way, I would bet if the trans isn't toasted now, it will be soon.
Just put a trap door in the floor board. When you need to back up, pop it open and Fred Flintstone it backwards.
Old 06-14-2008, 07:40 AM
I had a dream last night where my car had a hole in the floor for my feet so i could "pedal" it. I was chasing another car, but i lost them because i couldn't get up a hill.
