Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 06-11-2008, 12:37 PM
jdmcivic1999 jdmcivic1999 is offline
CEL is on, NEED HELP
OK i have a 04 Rodeo 3.2, and So lately my CEL has been coming on and off. I stopped at shucks and ran an OBDII test when it was on and came back as a p0420-Catalytic converter below threshold (Bank 1) The light will come on for a few days and than go off for a few days, what does that mean? Is this something to really worry about it right now? Is there a way to tell which Cat/oxy sensor needs to be replace? any help would be great
Old 06-11-2008, 08:59 PM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
Re: CEL is on, NEED HELP
Bank 1 is passenger side. Could either be the sensor or cat converter. If its the sensor it would be the one after the cat, those are the ones that check the condition of the cats. Not very common for them to fail though. You could swap the sensors side to side and see if the problem follows.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Old 06-11-2008, 10:40 PM
amigo-2k amigo-2k is offline
Isuzu Guy
agreed. swap from one side to the other. their will be a different code for the other side.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 06-12-2008, 12:32 AM
Cat Fuzz Cat Fuzz is offline
...and if it DOESN'T follow, meaning, you get the same code after swapping them, that most likely indicates a bad cat converter.
Old 06-12-2008, 02:05 AM
rod2004 rod2004 is offline
I have a 04 rodeo too.
so far so good up to now. So, how many O2 sensors does it have?
why so many?
2004 rodeo 3.2L 2WD
AISIN AT
http://www.isuzufaq.com/
http://forum.planetisuzoo.com/
http://isuzuforums.com/
Old 06-12-2008, 07:23 AM
Isuzu Guy
there are 4 of them. one infront of each Cat and one behind each cat.
-Ryan
Isuzu Moderator
Car Show Tips
Old 06-12-2008, 09:53 AM
Awesome guys, thanks for the help, ill try swapping them this weekend and see if that solves the problem.
