Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 06-10-2008, 07:56 PM
Armedgentleman Armedgentleman is offline
S Series Oil Consumption
I have read many posts that indicate that oil usage among higher mileage Saturns is normal. What is it that actually is responsible for the increase of oil use? Is it the piston rings, valve seals....? I would like to know that if I buy a higher mileage SL or SC what it would take to reduce oil consumption.
Thanks gurus!
Old 06-11-2008, 10:53 AM
RC1488 RC1488 is offline
Re: S Series Oil Consumption
oil rings to be exact. They get stuck and oil is allowed into the champer. A Murder Mystery Oil (MMO) soak usually has had great results for lossing the rings and reduceing oil comsuption.
Present: '02 Sl1 Man '01 SC1 Man '97 Sl2 Auto '96 SL2 Auto '95 SC2 Man
Past: '99 Sl2 Auto '97 Sl2 Man '98 SL2 Man '95 Sl2 Man '95 Sl2 Man '94 Sl2 man
Old 06-11-2008, 11:59 AM
Do you think I would be ok buying a 1999 SL2 with high oil consumption? Is there a good chance I could get it to come down a bit?
Old 06-11-2008, 12:05 PM
jer1303's Avatar
jer1303 jer1303 is offline
Send a message via ICQ to jer1303 Send a message via AIM to jer1303 Send a message via MSN to jer1303 Send a message via Yahoo to jer1303
Maybe with a new PCV valve, and a piston soak (I've done two on my SL1 with no improvement) - you might be able to get it down some. But don't bet on it.
'99 Malibu 2.4L 189k
'98 Windstar 3.8L 145k
Old 06-11-2008, 10:31 PM
Im sure you can get it down a little. As said a few MMO soaks and a good tune up and you should be alright. However its good to note that burning oil is NOT a bad thing meaning the engine is bad. It can be costly however, as you need to keep the oil at the right amount. Burning alot of oil (1qt every couple hundred miles) is expensive, but really thats the only thing bad with it.
