Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 06-10-2008, 07:04 PM
ttaylor61 ttaylor61 is offline
96 SC1 Dash lights do not work
A friend just bought a 96 SC1 and the dash lights do not work. Fuses are good and the tail lights work. I'm thinking it might be a bad dimmer switch. Any other thoughts????
Assuming on the outside chance I am right about the dimmer switch, how do you remove this switch?
Old 06-11-2008, 10:51 AM
RC1488 RC1488 is offline
Re: 96 SC1 Dash lights do not work
I would lean towards a badd dimmer also. Grab a volt meter and check resistance values as you turn the dial. IIRC you can pry it out with a screw driver, or reach behind it and push it out. I think there mayu be a tab on each side holding it in.
Present: '02 Sl1 Man '01 SC1 Man '97 Sl2 Auto '96 SL2 Auto '95 SC2 Man
Past: '99 Sl2 Auto '97 Sl2 Man '98 SL2 Man '95 Sl2 Man '95 Sl2 Man '94 Sl2 man
Old 06-13-2008, 10:56 PM
Trikeman72 Trikeman72 is offline
Send a message via Yahoo to Trikeman72
was easier to change out the steering column than the switch IMO
learned that watchin my buddy try to change one on his sc1 for a week and swaped out column in like half n hour
Old 06-16-2008, 09:34 PM
Hungrycat7's Avatar
Hungrycat7 Hungrycat7 is offline
My sister had same car, same year, and same problem. I started out looking for fuses but all were fine. Replaced the dimmer switch and still nothing. Ended up taking it somewhere just to have someone tell me the bulbs were actually burned out! PITA to get to but a pretty cheap fix.
