Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 06-10-2008, 05:30 PM
abovenbeyond's Avatar
abovenbeyond abovenbeyond is offline
Rear end question???
Hello all,
I have a rear end starting to get noisy, I just had the oil changed and they said they checked the level, it was a little low, but now much the guy said.
SO...
If I change out the read end is there any better then the other... besides the 9c1 (8.5 I think it is) Anyways if I go wrecking yard hunting, I may as well look for a change now if I am going to.
What about gearing, the stock I think is 3.08, is there a better option that came in another car/year?
Old 06-10-2008, 07:36 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Read end question???
3.08 is probably the best compromise between tire-smoking torque and $4.25/gal gasoline usage. You might be able to go with a 3.42 but in my experience, it didn't add a lot of 'oomph' to the car, certainly not enough to justify the increased fuel usage (went from 19/gal highway to 16/gal highway). You haven't told us what you are driving, so I can't help you as to what you have.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 06-10-2008, 08:31 PM
CD Smalley CD Smalley is offline
Your 91 should have 3.42s I believe. Take a look at your SPID and look for a code there like GU4 or something similar.
Let's figure out what you have now before swapping something out.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 06-11-2008, 10:42 AM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
Re: Rear end question???
Speaking of rear ends and gas prices, That 2.73 reary in my car that I wanted to get rid of for so long... It's never looked better to me right now.
Old 06-11-2008, 11:08 AM
Sorry I have the 91 Caprice, I will check the code in a few minutes...
1991 Caprice Classic
Old 06-11-2008, 07:20 PM
I did find a GU4 code, amongst many others. lol But there is a GU4. That likely mean 3.42?? That's not bad, maybe i will see about having the rear end fixed then...
Old 06-11-2008, 07:45 PM
silicon212's Avatar
Confoundingly Lucid
Gu4 = 3.08
Gu5 = 3.23
Gu6 = 3.42
