Go Back   Automotive Forums Car Chat > Geo > Tracker
Old 06-10-2008, 02:30 PM
pvtcook pvtcook is offline
96 tracker wont idle when warm
My tracker idles fine until it get up to operating temp then it wont idle. Any ideas? TP sensor Coolant temp sensor? Runs great just wont idle.
Thanks
Old 06-10-2008, 07:21 PM
Scotty89's Avatar
Scotty89 Scotty89 is offline
Re: 96 tracker wont idle when warm
I have the same problem with my 96 tracker. I still havent found the problem.
Old 06-10-2008, 07:39 PM
ernestfortier ernestfortier is offline
I had a problem kind of like yours. My idle, for a while was fluctuating anytime I changed the shifter on the Auto trans from in gear to out of gear. I also had the check engine light come on. Looking at the engine, on the left at the rear is a small steel line that feeds the EGR valve. If it clogs up enough it will mess with the idle. You pretty much have to remove the steel line. It faces downward towards the EGR. Remove the two bolts on the intake manifold, the one bolt further down that keeps it stable and the two bolts on the EGR. Now blow through it with lots of pressure. Now use a small wire and poke it through the opening in the intake manifold, that is more than likely where the clog is. If you clean the clog out good enough you will get a peerfect idle.
