Go Back   Automotive Forums Car Chat > Saab > 900
Old 06-10-2008, 11:03 AM
tim1210 tim1210 is offline
Are the headlights automatic?
I have just bought a 95 900S convertible. I have a headlight switch that doesn't seem to do anything. The lights always come on when I start the car. Along with this problem, I have no dash lights except for a split second when I turn the key on. So I know they work but they fade out. Wondering if a new headlight switch could fix this and wondering if previous owner rigged something to make the headlights come on all the time. Any help would be greatly appreciated.
Old 08-02-2008, 02:43 PM
Mordac85's Avatar
Mordac85 Mordac85 is offline
Re: Are the headlights automatic?
I just fixed this one! It's actually the panel dimmer switch causing the problems. You may still have something wrong with that headlight switch, but I know the fading instrument panel lights are caused by the dimmer.
Old 10-05-2008, 09:21 PM
94saab900 94saab900 is offline
I have a 1994 Saab 900s. The parking lights work when the ignition is off but not the headlamps. This is partly so you don't kill your battery in the case that you leave your lights on. The owner's manual says that the parking lights are to be on only when the car is off and in emergency situations. If you try to turn them on while the ignition is on, the headlights will come on instead.
