| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
2g Coil Question????
ok first off ... can anyone PLEASE tell me what the little silver cylinder is that is bolted by 1 bolt to the intake manifold on the timing belt side and has 1 black wire running to it. this fell off my car and I lost it and now my car will not start? is this possible .. what is the roll of this little cylinder. and what is the name... also I have a new power transister i put in to try and diagnose this problem. and also will a 1g coil pack work on a 2g or must it be a 2g coil pack... thanks soo much in advance!
96 GST
Re: 2g Coil Question????
i was told once that is like a trasnsistor, i cant remember the words this guy said but it's so that your engine noise wont go to your speakers.
-MODS-Autometer Boost,Oil Presure,And Water Temperature Gauges./Geddy Turbo Tmer/Eibach Sportline Springs Matched With Adjustable Iluminas 4 Corners/Konig 18" On Nitto Extreme 555/ACT 2100 PP with Street Disc/Extended Push Rod/Urethane Motor Mounts/XS Power FMIC. 28X10.5X3.5/Greedy Type RS BOV/ evo3 16g Turbo/MBC At 18PSI/Bian Crower 272 cams/SAFC2 With 510cc Injectors/Walbro 190 FP/ 1/4 mile=14.3@103MPH |
ye i ended up replacing it and still no spark... i changed the transister and still no spark... i only have a spare 1g coil but im still not getting spark... I am wondering if a 1g coil will work on a 2g ? does anyone know.... thanks tons in advance
96 GST
should work, i believe the only difference is the firing order.
Are you getting fuel? If you've changed the coil and transistor module and still getting no spark the next most likely culprits are the CAS and the ECU. If you are not getting the trigger to the injectors as well it's more likely to be the CAS. Remove the CAS (you'll have to set base timing after you do this, so make sure you have a timing light and know how to do it), turn the key on, and turn the cas by hand. You should hear the pump prime and hear the injectors clicking, and see spark if you have a connected spark plug laying out on something grounded where you can see it. This is all true for a 2g, and I'm 99% sure it's true for a 1g as well.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
