Proper Sensor Readings
Hello all. I just purchased myself an ElmScan 5 OBD-II tool for my 2000 Grand Marquis and a few other family vehicles to make sure they stay in tune. I was curious if any of you know where I can find the proper sensor readings. I am able to see sensor readings of MAF, MAP, TPS, coolant temp, O2 sensors, etc. I'm not sure what the normal ranges for these sensors should be. I would like to know so I can compare with mine to ensure that all of the sensors are working properly and that the engine is tuned properly.
Thanks in advance! |
Re: Proper Sensor Readings
These are for 2001, but they will be the same.
2001 PCED On Board Diagnostics II SECTION 6: Reference Values Procedure revision date: 06/02/2003 ________________________________________ 4.6L Crown Victoria/Grand Marquis Typical Diagnostic Reference Values Sensors/Inputs PCM Pin/PID only Measured/PID Values Units Measured/PID KOEO Hot Idle 30 MPH 55 MPH FLI V/FLI 9 1.7/50 1.7/50 1.7/50 1.7/50 DCV/% FEPS 13 .5-.6 .5-.6 .5-.6 .5-.6 DCV CKP (+) 21 0 440-490 560-780 900-1100 Hz TCS 29 .1/0FF VBAT/ON (G) .1/OFF .1/OFF DCV/OFF-ON TR 1 34 0 0 11.5 11.5 DCV 02S12 35 .1 (D) (D) (D) DCV TFT 37 .5-2/210-110 .5-2/210-110 .5-2/210-110 .5-2/210-110 DCV/DEG IAT 39 1.7-3.5/120-50 (K) 1.7-3.5/120-50 (K) 1.7-3.5/120-50 (K) 1.7-3.5/120-50 (K) DCV/DEG FPM 40 .1/OFF VBAT/ON VBAT/ON VBAT/ON DCV/OFF-ON ACCS 41 .1/OFF VBAT/ON (A) .1/OFF .1/OFF DCV/OFF-ON TR 2 49 0 0 11.5 11.5 DCV TR 4 50 0 0 11.5 11.5 DCV VSS (+) 58 0 0 65/30 125/55 Hz/MPH O2S11 60 0 switching (C) switching (C) switching (C) DCV 02S22 61 0 (D) (D) (D) DCV FTP V/FTP 62 2.6/0 2.6/0 2.6/0 2.6/0 DCV/IN-H2O TR V/TR 64 0/PARK 0/PARK 1.7/OD 1.7/OD DCV/MODE DPFEGR 65 .25-1.30 .25-1.30 .25-4.65 .25-4.65 DCV CHT V/CHT 66 .67 or 3.7/194 .67 or 3.7/194 .67 or 3.7/194 .67 or 3.7/194 DCV/DEG OSS 84 0 0 126-136/ 1260-1330 225-243/ 2265-2400 Hz/RPM CID 85 0 6-7 10-11 13-14 Hz ACP 86 VBAT/OPEN VBAT/OPEN VBAT/OPEN VBAT/OPEN DCV/OPEN- CLOSED 02S21 87 0 switching (C) switching (C) switching (C) DCV MAF V 88 0 .6-.9 .9-1.5 1.4-2.1 DCV TP V 89 .53-1.27 .53-1.27 1-1.2 1-1.3 DCV BPP 92 .1/OFF VBAT/ON (E) .1/OFF .1/OFF DCV/OFF-ON CPP/PNP PID ON ON OFF OFF OFF-ON GEAR PID 1 1 3 4 GEAR LOAD PID (L) 15-19 20-26 23-28 % MISF PID OFF OFF OFF OFF OFF-ON OCTADJS PID NO RETARD NO RETARD NO RETARD NO RETARD RETARD/NO RETARD RPM PID 0 790-815 1250-1400 1540-1620 RPM Actuators/ Outputs PCM Pin/PID only Measured/PID Values Units Measured/PID KOEO Hot Idle 30 MPH 55 MPH CDE 1 VBAT VBAT VBAT VBAT DCV MIL 2 .1/OFF VBAT/OFF VBAT/OFF VBAT/OFF DCV/OFF-ON SS1 6 .1/ON .1/ON VBAT/OFF .1/ON DCV/OFF-ON SS2 11 VBAT/OFF VBAT/OFF .1/ON .1/ON DCV/OFF-ON TCIL 12 5/OFF 5/OFF 5/OFF 5/OFF DCV/OFF-ON CDA 26 VBAT VBAT VBAT VBAT DCV CDF 27 VBAT VBAT VBAT VBAT DCV LFC 28 VBAT/OFF .1/ON (B) VBAT/OFF VBAT/OFF DCV/OFF-ON CHTIL 45 4.7/OFF 4.7/OFF 4.7/OFF 4.7/OFF DCV/OFF-ON HFC 46 VBAT/OFF .1/ON (B) VBAT/OFF VBAT/OFF DCV/OFF-ON EGRVR 47 VBAT/0 VBAT/0 10.5-VBAT/ 0-40 8-11.3/ 39-50 DCV/% CDB 52 VBAT VBAT VBAT VBAT DCV CDG 53 VBAT VBAT VBAT VBAT DCV TCC 54 .2/100 VBAT/0 9.9-10.1/42-44 .3/90-100 DCV/% EVAPPDC 56 0 0-10/0-100 0-10/0-100 0-10/0-100 Hz/% EVAPCV 67 0 0-10/0-100 0-10/0-100 0-10/0-100 Hz/% WAC 69 VBAT/OFF .1 /ON (A) VBAT/OFF VBAT/OFF DCV/OFF-ON INJ7 72 0 3.4-3.7 3.7-6 5.5-9 mS INJ5 73 0 3.4-3.7 3.7-6 5.5-9 mS INJ3 74 0 3.4-3.7 3.7-6 5.5-9 mS INJ1 75 0 3.4-3.7 3.7-6 5.5-9 mS CDC 78 VBAT VBAT VBAT VBAT DCV CDH 79 VBAT VBAT VBAT VBAT DCV FP 80 VBAT/0 .1/100 .1/100 .1/100 DCV/% EPC 81 7.9/20 9.5/20 9.3/22 9.5/22 DCV/PSI IAC 83 VBAT/0 9.2-10.3/32-36 8.3-10.7/30-55 5.7-8/40-70 DCV/% HTR11 93 .1/ON (P) SWITCH SWITCH SWITCH DCV/OFF-ON HTR21 94 .1/ON (P) .1/ON .1/ON .1/ON DCV/OFF-ON HTR12 95 .2/ON (P) SWITCH SWITCH SWITCH DCV/OFF-ON HTR22 96 .2/ON (P) .2/ON .2/ON .2/ON DCV/OFF-ON INJ8 98 0 3.4-3.7 3.7-6 5.5-9 mS INJ6 99 0 3.4-3.7 3.7-6 5.5-9 mS INJ4 100 0 3.4-3.7 3.7-6 5.5-9 mS INJ2 101 0 3.4-3.7 3.7-6 5.5-9 mS CDD 104 VBAT VBAT VBAT VBAT DCV FUELPW1 PID (L) 3.4-3.7 3.7-6 5.5-9 mS FUELPW2 PID (L) 3.4-3.7 3.7-6 5.5-9 mS LONGFT1 PID (-)20-(+)20 (-)20-(+)20 (-)20-(+)20 (-)20-(+)20 % LONGFT2 PID (-)20-(+)20 (-)20-(+)20 (-)20-(+)20 (-)20-(+)20 % SHRTFT1 PID (L) (-)10-(+)10 (-)10-(+)10 (-)10-(+)10 % SHRTFT2 PID (L) (-)10-(+)10 (-)10-(+)10 (-)10-(+)10 % SPARKADV PID 0 15-20 20-35 32-38 DEG Other PCM Pin/PID only Measured/PID Values Units Measured/PID KOEO Hot Idle 30 MPH 55 MPH VPWR 71 VBAT VBAT VBAT VBAT DCV VREF 90 5 5 5 5 DCV NOTE: All generic OBD II readings under no load (PARK or NEUTRAL). GENERIC OBD II PID VALUES PID Hot Idle 2500 RPM Units LONGFT1 (-)20-(+)20 (-)20-(+)20 % LONGFT2 (-)20-(+)20 (-)20-(+)20 % LOAD 19-24 19-24 % MAF 4.7-6 13-16 G/S SHRTFT1 (-)10-(+)10 (-)10-(+)10 % SHRTFT2 (-)10-(+)10 (-)10-(+)10 % SHRTFT11 (-)10-(+)10 (-)10-(+)10 % SHRTFT12 95-100 95-100 % SHRTFT21 (-)10-(+)10 (-)10-(+)10 % SHRTFT22 95-100 95-100 % SPARKADV 15-20 40 DEG
Being way2old is why I need help from younger minds The sooner you fall behind the more time you'll have to catch up. ![]() HEY Y'ALL--READ THIS Here are some of our old vehicles for sale.
Thanks a ton way2old! This is a great reference.
way2old........you are way2smart.
HERS---> 2006 Grand Marquis GS (replaced my 1998 w/cracked manifold) HIS----> 2003 Dodge 1500 HEMI QC 4X4 |
Work at a place that has over 900 Fords in the fleet. Have lots of info from 2006 back. Working on trying to get 07, 08 and 09. Just got to figure how to place it so it can be read on the net.
