Old 06-09-2008, 05:28 PM
basanch73 basanch73 is offline
What scanner for cam retard
I have a Actron OBD II 9175 scantool, but don't see how it can check the Cam Retard. I need to change out my distributer gear on my '96 5.7liter Silverado and need to verify the +/- 2 degrees from 0 to ensure the timing is correct through the OBD II system. If anyone could help, I would greatly appreciate it.
Thanks,
Brian
Old 06-09-2008, 07:08 PM
777stickman 777stickman is offline
Re: What scanner for cam retard
Brian: You need to do some internet research for a good scan tool. The one you have seems to be a "code reader " and maybe a bit more. "cam retard" is also known as "cam offset", "cmp" and probably some other acronym's close to that. Expect to pay $500-$2000.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 06-09-2008, 11:33 PM
Thanks for the advice. I guess if the base autohobby shop doesn't have the capability, I'll be taking it to the dealer or someone for the final timing adjustment. Definately not investing that much into it!
Old 06-10-2008, 06:34 PM
Well, just found out that the base auto hobby shop has a few thousand dollar Snap On diagnostic scanner with all the adapters and circuit boards for all vehicle types that can read the Cam Offset.
Thanks!
