Old 06-09-2008, 05:24 AM
creslevi creslevi is offline
TPS (Throttle Position Sensor)
Replaced my TPS 2/6/08 worked fine till about 6/2/08
When I started car the engine would race, refused to idle and service engine soon light came on, If I unplug the TPS it idles fine, Question Are there any other sensors in that circuit that feed it information, or do you think I was just unlucky enough to get a bad replacement, I got it at Car Quest ?. It's on a 94 Buick LeSabre 3800. Thanks.
Rick
Old 06-09-2008, 10:45 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: TPS (Throttle Position Sensor)
Does the spring return on the TPS seem to be working? Have you tested the voltage on the blue wire with ignition on?
Old 06-09-2008, 12:19 PM
Hi
Thanks for the response, Yes the TPS does seem to rotate with the throttle shaft, No I haven't checked any voltage, I have been sick the last month with Heart problem, and can't get out to the garage (too weak) I am driving it with the TPS unpluged, But have no cruise control or passing gear, just trying to evaluate the problem ?.
Rick
Old 06-09-2008, 02:06 PM
happydog500 happydog500 is offline
When I replaced my TPS, it started dong what you discribe 6 months later. I reset the code, it ran fine.
Try clearing the code and plugging it in to see what happens.
I think mine did it twice, once more almost a year later. I just reset the code and it has been fine ever since (couple years?).
Chris.
Old 06-09-2008, 03:09 PM
Thanks for the suggestion, as soon as I am able I will give it a try, I think you just unhook the battery a few minutes to reset the codes ?.
Rick
Old 06-09-2008, 04:25 PM
inafogg inafogg is offline
i think on your car u would be ok since its OBD 1 but not on obd 2 systems (96 & up)of course using a scanner is always best.Good Luck & hope u recover soon!!
Old 06-09-2008, 05:46 PM
Mine is OBD 2, even overnight didn't clear the codes. I had to use a scanner. the other post said OBD 1 is different, so it might work.
Chris.
Old 06-09-2008, 06:49 PM
I tryed clearing the code, Service engine soon light went out but the engine still raced
Rick
Old 06-09-2008, 06:56 PM
Blue wire is .06v, i forget what it should be ?, This thing has always been soo dependable I am shocked to have this problem in 6 mo after paying a shop $195.00 to read & clear the codes and install the new sensor $80.00, They said they also replaced the throttle body gasket ?.
Rick
Old 06-09-2008, 08:27 PM
HotZ28's Avatar
AF Moderator Elite
That is too low, it should be around .45v and no more than .50v! What is the idle rpm? Are you sure the T/B is closing all the way?
Old 06-09-2008, 09:08 PM
As soon as I unplug the TPS it returns to normal Idle speed, What might cause the high Voltage ?.
Rick
Old 06-10-2008, 07:16 AM
HotZ28's Avatar
AF Moderator Elite
You should now check the grey wire, (PCM reference voltage) it should be 5.0v. If this checks out, I would suspect the TPS is at fault. BTW, are the TPS mounting screws tight?
Old 06-10-2008, 08:56 AM
Yes the screws are tight, I will try to check the grey wire today sometime.
Thanks Rick
Old 06-10-2008, 11:42 AM
HotZ28's Avatar
AF Moderator Elite
While you are at it, check the low voltage again. Your previous reading does not correspond to a high idle condition. If the reading on the blue wire @ idle position is actually .06v, the engine would probably not run at all.
Old 06-10-2008, 11:44 AM
I don't have a grey wire, mine is kinda blue, with engine idling it say's 5.5v with it plugged into the TPS, I shut it off and restarted several times and so far it idles fine, but at this point don't know how long it will last ?.
Rick
