Go Back   Automotive Forums Car Chat > Oldsmobile > Achieva
Old 06-08-2008, 09:57 PM
Jbrove Jbrove is offline
Howto: Program Achieva remotes
The procedure is simple, first pull back the lining along the back lefthand side of the trunk. Inside will be the remote receiver module. Coming out of the receiver module is a loose two-pin connector. To program remotes, simply short the two leads of this connector (The locks will cycle) and press any button on each of the remotes you want to use. When you are done, un-short the leads.
