Go Back   Automotive Forums Car Chat > Dodge > General Discussion
Old 06-08-2008, 09:27 PM
1320-camaro-383 1320-camaro-383 is offline
Air conditioning question
I have a o1 caravan that the ac compressor was junk so I replaced it and filled with 134.It was about a can low but was working good for about a day and then stoped working.I thought I sprung a leak so I put a gauge on it and it read about 100 psi when it should be 45 psi or less.Im clueless on what happened.The only thing I can think of is the old compressor had a lot of mettal chunkes in it,I blew out the lines with air but it didnt want to blow through.Maybe the drier is clogged causing the pressure to raise and the pressure switch shutting down the system.Anyone have any experience with this kind of problem?Thanks in advance
Old 06-20-2008, 08:47 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Air conditioning question
It's possible the orifice tube (OT) is clogged with debris since that is downstream of the compressor. It's usually a PITA to get to since it is located right before the evaporator, but compressor failure usually necessitates removing and cleaning or replacing the OT as well. Ditto the accumulator if the system has been exposed to air for more than a brief period...the dessiccant absorbs water and becomes saturated.
I'm just learning auto a/c myself, so take this all with a grain of salt. Backflushing the OT may not be enough if there's alot of crap in there. With that small an orifice, you can't get much air velocity to dislodge any debris from the filter mesh. Discharge, clean or replace the OT, evacuate and recharge with the proper weight (not pressure) of R134a.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 06-20-2008, 08:59 AM
brcidd's Avatar
brcidd brcidd is offline
What you have said above is fine with the exception that Caravans use an expansion valve and not an orifice tube-- and a receiver dehydrator- not an accumulator. The TXV (thermal expansion valve) is on the liquid line in front of evaporator entrance on firewall- engine side..
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 06-20-2008, 09:08 AM
jdmccright's Avatar
The RustBuster
My mistake, I assumed that the expansion valve & receiver/drier setup had fallen out of favor on newer vehicles. Apparently not completely.... Thanks for the correction.
If that's the care, there may also be ice forming in the expansion valve due to excessive moisture. I'd still pull it & clean/replace it and the receiver/drier. Evacuate well and check for leaks. Recharge.
Told you I'm still learning this stuff
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
