Old 06-08-2008, 04:16 PM
akirmanidis08 akirmanidis08 is offline
zc injector swap issue
so ive got the zc swapped into my crx. started up and everything.
the only problem is that its running only on 2 cylinders.
A7 and A3 are the main injector and auxiliary injector on the DPFI side
for the MPFI transfer A7 and A3 become injector 2 and 4
for some reason only injectors1 and 3 and running. ALL of the spark plugs are getting spark though.
the wiring has been checked twice over and everything is good from the resistor box all the way to the ecu.
anyone know what possibly could be causing injector 2 and 4 not to be firing?
Old 06-09-2008, 01:05 AM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: zc injector swap issue
You are running a mpfi ecu right?
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 06-13-2008, 04:56 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
You have a wire on the wrong pinout, most likely... I know you say everything is good, but if you're running an MPFI ECU, etc... then that's almost definitely what it is.
Old 06-13-2008, 04:57 PM
either that, or you have a bad connection somewhere.. make sure nothing is taped up, and solder all your connections... if you don't, eventually, you may regret it..
Old 06-13-2008, 10:03 PM
ok sorry i havent gotten back to check posts.
but here it is.
i have a zc ecu. pm7
wires have been checked over twice and more. but i ordered a premade harness off of ebay so we will see how that works.
could it be that i have a bad ecu?
Old 06-13-2008, 10:04 PM
what do you mean by a wrong pin out btw?
Old 06-14-2008, 06:06 PM
You're supposed to change a couple pinouts when you do the wiring from DX to ZC.. a pinout == an area where a pin is attached to the wiring connector that plugs into the thingy, and allows the wire to make contact with another circuit.
Old 06-15-2008, 02:19 AM
FrodoGT's Avatar
Hes saying you may have some pins in the wrong holes on the ecu connector.
Current project:
Rio Red 91 hatch.
Old 06-15-2008, 12:31 PM
thank you... I couldn't explain that correctly... lol
