Old 06-07-2008, 08:55 PM
northern piper's Avatar
northern piper northern piper is offline
leaky thermostat housing 2000 3.8
So I've been trying to track down a minor (but annoying) coolant leak on my 2000 3.8. Coolant always seems to collect as a result of this leak just under where the brake pressure sensor is. There is a little fin on the block which creates a reservoir that'll hold 1/2 ounce or so. Anyway, I've come to realize that the thermostat housing at the bottom is leaking slightly. Yes there is a gasket and the bolts are torqued to the correct value and the t-stat is in the right way. Has anyone ever had the housing be not flat? When I redid the coolant about 2 months ago I sanded the housing as there was evidence of a bad casting. It just pisses me off that I have to do this and loose all the coolant in doing so. Do people use a gasket sealant here or just the gasket? Ford says to only use the gasket but I'm beginning to wonder.
Piper
2000 windstar 3.8
2010 honda pilot touring
Muskoka Canada
Old 06-07-2008, 10:17 PM
12Ounce 12Ounce is offline
Re: leaky thermostat housing 2000 3.8
I've had the same misterious/annoying leak for a long time. I assumed it was my own poor workmanship as I had replaced the thermostat "way back when". It can be a tough area to reach. This last time, during overhaul, I made sure mating parts were clean and properly located, and I used a thick paper gasket lubed with petroleum jelly (my practice). It seemed to seal-up OK this last go-round.
However, the reused thermostat is opening too soon to suit me ... the engine is slow to warm up. So I will be doing it all over again.
Old 06-08-2008, 02:52 AM
tripletdaddy tripletdaddy is offline
I spoke to a mechanic friend of mine who said that because gaskets historically have given problems as they age. They will dry up, shrink and crack allowing a leak. He said the new assembly practice is no gasket at all and just use RTV sealant. I didn't know Ford said NOT to use any sealant on the gasket or metal surfaces. More often, I have read across several different manufacturers to use sealant to at the very least to aid in holding the gasket in the right place. In your case, I wouldn't hesitate to use a sensor safe sealant.
Old 06-08-2008, 07:15 AM
Ya, I think I'm going to have to use some sealant. I find that my local Ford parts/advice is unreliable. There is 1 guy there who used to be a mechanic who has never lead me wrong. The 2 other guys will "advise" you but their advice always seems to have some bugs.
The Ford gasket is about as thick as 2 sheets of paper. Is there a better gasket or material I could use? I'd love to get some 1/16" thick cork or something in there along with the gasket sealant I'll use now.
Piper
2000 windstar 3.8
Muskoka Canada
Old 06-08-2008, 09:26 AM
My thick gasket came in the engine overhaul gasket set, I believe.
You could also just use a "stack", two or three perhaps, of the thinner ones. This should take care of a great deal of surface irregularities.
I find that petroleum jelly on water hoses and water gaskets is a lot more forgiving (less clean-up) than other sealants when it comes time to "go back in".
Old 06-08-2008, 07:06 PM
I've seen at least two types of cut your own gasket sheets in a roll at the auto parts stores (Advance and maybe Auto Zone, Napa and Carquest I'd expect too). One was a heavy weight paper or light weight card stock, and the other was a thicker cork. Maybe if you had a beltsander, you could get that tstat housing more flat.
12ounce, I like using the p jelly too for hose and similar assembly for later removal, but I never considered it for gasket surfaces. Cleanup and removal would be easier, I'll consider trying it, but I'd still rather use RTV on poor mating surfaces.
