Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 06-07-2008, 08:23 PM
mejkwilliams mejkwilliams is offline
Cool 93 clutch or transmission problem? Help please
We just bought a 1993 Geo Prism 5spd. When we test drove it- it seemed the clutch had to come almost all the way up before you would move (all cars are different though, so we didn't think much about it). We put it on the road today and started driving it- While in gear if you push the gas hard it will slip- it's like the rpms are reving but you are no speeding up as you should (hope that makes sense). We checked some fluids, not sure how many we should check...also any tips on changing the clutch if that seems to be the problem- Thanks
Old 06-09-2008, 10:25 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: 93 clutch or transmission problem? Help please
The '93s clutch is hydraulic and non-adjustable. If it is slipping under load then the clutch face and disc are worn and need to be replaced. This is not an easy task unless you have the garage space to jack up the car and remove the manual tranny unit. If you're unsure, take it to a good tranny repair shop...usually between $300-$400 for a new clutch pack installed. Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
