Go Back   Automotive Forums Car Chat > Geo > Nova | Prizm | Spectrum | Sprint
Old 06-07-2008, 08:21 PM
mejkwilliams mejkwilliams is offline
Cool Cluth or Transmission?!?! 93 Prism
We just bought a 1993 Geo Prism 5spd. When we test drove it- it seemed the clutch had to come almost all the way up before you would move (all cars are different though, so we didn't think much about it). We put it on the road today and started driving it- While in gear if you push the gas hard it will slip- it's like the rpms are reving but you are no speeding up as you should (hope that makes sense). We checked some fluids, not sure how many we should check...also any tips on changing the clutch if that seems to be the problem- Thanks
Old 02-27-2009, 06:07 PM
zq3mpaj2 zq3mpaj2 is offline
Re: Cluth or Transmission?!?! 93 Prism
I'm having a similar issue with my 94 prizm lsi 1.6L manual trans. 166000 miles. I've begun to notice that when going uphill, if I push on the gas more than a little, the rpms go up more than the car is accelerating. It does not slip out of gear and there is no noticeable noise from the transmission. It just takes a few seconds for the speed to catch up with the rpms. I don't think this is normal. I've had other vehicles with manual trans. and never noticed this. Also I've have this car for 5 years and just recently this started occurring. Any help greatly appreciated. thanks
Chris
Old 05-21-2009, 02:37 AM
kennyspackers kennyspackers is offline
Check the clutch resevoir, it is on the firewall drivers side if that is low or empty add some brake fluid. If not then it is the clutch, going uphill gaining RPMs but not speed is definetly the clutch.
Old 06-09-2009, 10:19 AM
srt4killsu srt4killsu is offline
Chris
It sound like the clutch is going out. Does it do it if you down shif to a lower gear? if not the cluch is going. Is there a smell after it does it like burnt brakes? If so your clutch is slipping
05 Srt4. Mods: ACT 6 Puck Clutch, Wisco pistons 8.8-1, Eagle rods, BC cams and valves, adj. cam gears, Race ported head, Ported intake mani, 55mm TB, 3" TBE, 255l pump 1100cc inj and Diablo sport. Oh yeah and Twin Turbos 603hp on meth inj. and pump 92
