Old 06-07-2008, 06:23 AM
carlxie007 carlxie007 is offline
new guy
hey, everybody, yeah, i'm a new guy to this forum.
I'm gonna ask a question that many other may already asked, but i want answer that help me to solve in where i live.
so here's the common question:
1, how to remove old paint off the model car? and what can i get from Australia (most importantly)?
2, how to strip parts off a assembled kit? it just one of my old finishes, and i wanna repaint everything again.
thanks for everyones' time.
Old 06-07-2008, 07:03 AM
stevenoble's Avatar
Re: new guy
Hello and welcome.To answer your questions.
1: Depends what paint you have used to paint it.Enamels I use Mr Muscle oven cleaner.Anything else isopropyl alcohol 91%+ strength.With the oven cleaner place the parts to be stripped in a plastic sandwich bag, spray in the oven cleaner, allow to soak for a good few hours, then remove and scrub the parts.Repeat if necessary.With the alcohol pour the alcohol in a suitable tub with a sealed lid and soak the parts to be stripped in the alcohol overnight.Next morning remove the parts and scrub off the old paint.It may take a couple of soaks to remove all the paint.
2: Depends on the type of glue you have used for assembly????
Steve Noble
Old 06-07-2008, 07:06 AM
rockinanko's Avatar
rockinanko rockinanko is offline
Re: new guy
Hi, aussie new guy! welcome to AF!!!
1) my method of removing paint from body is using brake fluid. it works excellently for de-chroming too! but do test out the plastic to see if the fluid 'attacks' or not!
2) my method is 'freezing the whole item in the fridge for a day...then gently knock them off one by one. but there's no guarantee part won't break ok!?
hope it helps!
cheers
marc
SSGP
I can feel the adredalin,
the same adredalin of what it's like...
to be a classic ferrari coachbuilder.
Old 06-07-2008, 08:00 AM
Smile Re: new guy
thanks for the quick reply, guys.
I use tamiya products in all my works.
the model car has been assembled for a while too.
for the aussie answer? if i put it in the freezer, am i suppose to just sand the marks off?
cheers
Old 06-07-2008, 09:38 AM
rockinanko's Avatar
Re: new guy
well, in general yes.
the last time i tried to de-glue a model car it works quite well, only a couple of broken inserting studs. please make sure you put the item in a ziplock bag for hygiene sake before freezing!
there may be more methods in de-gluing the item...stay tune for more replys from the other modelors...
marc
SGP
