Old 03-06-2003, 08:53 PM
SaberX SaberX is offline
Are the 1997 Firebird's any good???
The dealer has one for sale that i'm thinking about buying.
It's a 1997 firebird , 3.8L,5 speed,
What should i look for when i take it for a test drive?
The car is very cleen with low Km's(it's in Canada).
New brakes,t-bar,new tires,ect.
I never had a car like this befor and just want to know what should i look for.
Bill
1997 Black Firebird 3.8 V6,
Mods coming soon...
Old 03-07-2003, 07:42 AM
Gripenfelter's Avatar
Gripenfelter Gripenfelter is offline
Honorary Mod
Send a message via ICQ to Gripenfelter
The V6s are very reliable.
Look for rear pinion seal leaks.
Old 03-11-2003, 06:45 PM
Scott 02's Avatar
Scott 02 Scott 02 is offline
Banned
Send a message via AIM to Scott 02 Send a message via Yahoo to Scott 02
Right, Check around the Rear End area for leaks and check around the oil pan. Also see how the suspension is by turning the car right to left so that it has a little roll in it. One more thing is check the front tires. The reason I say front tires is, usually any person with a 5-speed RWD car will do a few burnouts pretty easy and usually the dealer just rotates the tires.
Old 03-11-2003, 07:10 PM
Thanks for the replays.I went and bought the car after.Everything turned out perfict with the car.Also i got the name of the last owner and i was sursprized to find out she lives nexed door to my mother.So i went over and talked to her about the car.
The firebird came only with winter tires.Witch are almost new.
I will be looking for a nice set of summer tires for her next.
Mods coming soon...
Old 03-12-2003, 07:18 PM
Scott 02's Avatar
Banned
Sounds like you found a good firebird and at least a lady was the owner of it before. Not some kid....
Old 03-13-2003, 01:19 PM
FFCCPresident's Avatar
FFCCPresident FFCCPresident is offline
Send a message via AIM to FFCCPresident
Thumbs up
Sounds like you got yourself a nice car there! Good luck and have fun!
President and Founder of the Firebirds Forever Car Club. Check us out at http://www.firebirdsforever.cc
Old 06-08-2003, 04:21 AM
HotRoder HotRoder is offline
Banned
My 97V8 bird is a blast....for like 14 g's , its worth it , so much more fun then a V6, if you get the LT1 you will be happier. on the v6 you will most likely blow the head gasket within 110 k miles. if you have an oil leak check oil pan, valve covers, crank and pinion seals. check if the gears whine to check for a bad DIF gear box. see if it overheats, check for any strange noises like ticking or or bell like sound in the engine. Also check the exhaust for a blue tinge or real white tinge. If you check the ECM you can see what problems the car may have had and still has after the battery may have been disconected to hide a check engine light. Change the oil and filter every 3 k miles and check your collant level. there is a choke vavle on the upper radiator pump leading to the thermostat housing...to get bubbles out of your radiator lossen the screw while the engie is runnin but not to much only a little!! This will cause better flow of collant and proper use of the radiator cap venting (RT) recovery tank presure.
Old 06-08-2003, 04:27 AM
Banned
My fault, you already own the new bird, thats good. YOu will have better insurance rates, good gas millege, and a less noisy engine being less of a cop magnet. It was a good choice, the ladies love the bird its a pimp mobile.
are MMATS wavedrive subs any good? d-unit's_brother Car Audio 0 11-12-2006 03:22 PM
are street import headers any good??? frstwht2gengsr Integra 1 08-24-2005 08:53 PM
are parts yards really any good? new_driver Cars in General 3 08-09-2005 11:36 PM
Are Fujimi Work Emotions any good? Bookshelf Car Modeling 12 07-03-2004 05:48 AM
Are porterfield brake pads any good? sw20junkie 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 3 06-04-2004 01:21 AM
