Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 06-05-2008, 01:36 PM
gdriver gdriver is offline
Question Sloppy Shifter feel
Hey all-
I just took over my brother's '99 lx sedan and the shifter just feels strange to me. It's like when I put the car in first gear, I can push the shifter over to the right towards third gear and it feels like when I have the car in neutral pushing it over to go to 5th. I drove a '93 dx 5spd until i blew the head gasket, and it felt very solid when it was in gear. Is this normal feel for the
'96-'00s, and is there anything I can do to improve the feel?
thanks
Old 06-05-2008, 05:50 PM
sportsterguy3421 sportsterguy3421 is offline
Re: Sloppy Shifter feel
Sound a bit loose to me, maybe your brother was a bit ruff with it. Might be worth a short throw, the tend to come with the hardware that would take up a large amount of slack.
Old 06-06-2008, 08:24 AM
any options besides a short throw?
Old 06-06-2008, 05:32 PM
If that truly is the problem you could try to replace the bushings but that may run you just as much... I think the dealer would be the only place to get those kind of replacement parts. Might be worth going to a parts house just in case.
Old 06-06-2008, 08:33 PM
if the prices would be similar, which would be easier? I'm fairly mechanically inclined, but I don't have the equipment to do serious work around the transmission
Old 06-07-2008, 09:22 PM
Should need much more than a socket set and screw drivers, if you take your time it shouldn't be anything more than a few hour, either way you do it.
Old 06-09-2008, 02:47 PM
Alright guys sounds good. Thanks for giving me the suggestions....not sure which I'll do yet, but its a place to start
Old 06-25-2008, 09:52 AM
daveimme daveimme is offline
Mine's sloppy too, so could you give us the lowdown what you did do and how difficult/easy it was?
Thanks.....
Dave
86 Accord LX (son #3)
93 Paseo (son #1)
99 Chev 1500 extended (son #2)
97 Civic EX (mine -will belong to son#4 next year)
08 CR-V (wife)
Old 06-27-2008, 02:39 PM
I've been busy working on my gf's cherokee, but when I get around to my car I'll let you know
Old 06-27-2008, 03:01 PM
Sounds good, would like to know.
Old 06-27-2008, 03:03 PM
kris's Avatar
kris kris is offline
Off playing with fire.
You should look at replacing these two bushings, either with OEM parts, or a stiffer aftermarket replacement such as energy suspension. These will typically stiffen up loose and worn components, without the need of some hack short shifter.
Here is a breakdown of your linkage.
Old 06-30-2008, 08:18 AM
Wow that's an awesome diagram! The bushings is the way I've been planning on going, just a matter of getting around to it. Hopefully I'll have some time this weekend
