Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 06-05-2008, 12:19 PM
todmil todmil is offline
wrangler and my starter
Hello All,
Long time lurker first time posting. Anyways,
My jeep has been running great for 2 years. I go to the jeep this morning and my starter doesn't turn and STARTS to SMOKE. Obviously I need to replace the thing. However, does anyone know why it would short out? The starter is about 4 years old and has about 30,000 miles on it. I have a car amplifier connected to my battery, other than that nothing else electrically has been added? ANY GUESSES?
thanks
todd
Old 06-08-2008, 11:22 AM
jmira29 jmira29 is offline
Re: wrangler and my starter
Sounds like the starter just wore out. Take it back and have it replaced. I'm guessing you got a lifetime warranty on it. You may want to check your fly wheel, see if there are any bad spots that are causing the starter to bind up on.
Old 07-06-2008, 07:00 AM
gtmud gtmud is offline
MAke sure you have a good ground and power connections to the starter( ground is usually the starter housing to block but check you ground to the engine block) ALso is th starter covered in oil. Mine was, caused it to go out, fixed the oil leak and r&r'd starter, works great.
