Old 06-05-2008, 12:02 PM
kosl kosl is offline
Elevated oil temperatures and bearing failure
At what temperature would oil (10w30) have to reach to cause extremely premature bearing failure? Links to any articles pertaining to this would be very much appreciated.
Old 06-06-2008, 09:10 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Elevated oil temperatures and bearing failure
For this "extremely premature" failure, all the oil, including the oil in the pan would have to be essentially on fire, or cabonizing, as it turns from a liquid into ash. This would require oil temp of at least 450 deg. F, for all the oil, including that in the pan.
This would produce so much engine smoke, from the fire, boiling coolant etc, it would be hard to miss when driving the car.
Usually overheated oil does not cause such an extreme catastrophic failure. Usually it produces oil 'sludge' or thich deposits over many thousands of miles that eventually blocks oil lines and passages, which causes engine (and bearing) failure due to oil starvation.
Old 06-06-2008, 05:48 PM
UncleBob UncleBob is offline
AF -Advisor
excessive heat over time can cause the oil to break down quickly. Air cooled engines would see over 300* F at times and it was recommended to do more frequent oil changes because of it. Otherwise it loses its viscosity and shere properties
most water cooled engines rarely get over 250* F. 180*F is considered a minimum to keep condensation out of the oil
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
