Old 06-05-2008, 08:42 AM
xjcamaro89 xjcamaro89 is offline
Might Get Rid Of My Clunkerado
Sorry guys but i might be getting rid of my 2002 silvy, just can take the unreliability of it any more, all the bumps and thumps and hard shifts and crappy gas mileage and replacing parts every couple weeks, its not what i bought a truck for. I know you take a chance when you buy a used vehicle, but this one takes the cake, i have never had this many problems with a used vehicle and put so much money into one in 6 months, even with one with double the miles. I just can take it any more!
My 2002 Silverado 1500
Old 06-05-2008, 09:13 AM
masapell's Avatar
masapell masapell is offline
Re: Might Get Rid Of My Clunkerado
Sorry for the bad luck!! I have always bought used, sometimes really used, but have been pretty lucky so far. In fact, my wife and I have only had one new car ever. This might actually be perfect timing for you to get something more reliable, fuel efficient, and worry-free. Keep us posted on what you decide. Sometimes there is a silver lining.
Sincerely,
Matt
2014 Ram 1500 Crew Cab
Old 06-05-2008, 09:31 AM
Looking at a (take it easy on me) Ford F150. So far on my truck since i got it in October i had put 4 new tires on it, brakes all around, all new steel brake lines, 2 alignments, went through 2 different Knock sensors, a transgo shift kit, all new shocks, changed rear end lube, 4x4 fluid, belt, AC tensioner, regular tensioner, spark plugs, wires, TPS, and i know there is more. And it rides so rough, still shifts hard, rear end clunks every now and then, only getting around 13 MPG with the 4.8. I have the piston slap, and when i change oil there is a nice carbon sludge around the magnet on the oil plug (which cant be good) I think this truck was really beat before i got it and its probably only going to get worse. Sorry.
Old 06-05-2008, 03:34 PM
Sonny01's Avatar
Sonny01 Sonny01 is offline
I had lots of trouble with my 2000 ext cab but the forum saved me thousands in repair costs. I now have a 2005 ext cab and it is a much better made truck.
Old 06-05-2008, 05:23 PM
sportsterguy3421 sportsterguy3421 is offline
Good idea! You should expand your choices before settling on something that may leave you in a similar situation.
Old 06-05-2008, 08:13 PM
Sonny01's Avatar
You win...you have had way more problems with your truck then I had with mine. I had continuous ABS and brake problems...those were the most expensive. Plus the normal maintenance for a truck with 113k miles on it.
Old 06-06-2008, 07:10 AM
So i got rid of my Silverado, and got a ford, sorry, but for the same money im paying for the chevy i could get this ford which is in alot better shape and alot more comfy than my silverado. I think i worked on my silverado since the day i pulled it out of the lot. And i hated coming on these boards cause every problem or symptom i saw people had, i knew i had it with mine. Thanks for all your help though guys!
Old 06-06-2008, 05:11 PM
kahjdh's Avatar
kahjdh kahjdh is offline
Now your running into timing chain territory, If it is a 5.4 make sure the spark plugs have been replaced avery 50k or you will be pulling the heads.
Sorry about your truck, nobody makes good cars anymore.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 06-12-2008, 07:23 AM
Ok, sorry guys but i did it, i got rid of my chevy and got a ford, it was nice being here and you guys helped me with a lot, im not a complete ford man though, i still have a camaro. But thanks again, and maybe if i get courageous ill come back to a chevy sometime down the road!
Old 06-13-2008, 06:52 PM
silveradofirerescu silveradofirerescu is offline
Good luck, I had a 2005 ford piece of poo F150. I got 10. maybe 12 mpg with the 4.6 motor and no towing package. My 2002 silverado gets close to 18 now that I have slowed down with the 5.3 and a towing package. I will never buy another ford. The really bad part was the ford was new and the chevy has 220K on it...
Old 06-19-2008, 07:37 PM
j cAT j cAT is offline
xjcamaro 69 screwed with his vehicle too much.....you cannot get more power and higher gas mpg's.....buying the ford 150 is going backwards as far as mpg is concerned.....they are the worst in mpg in this truck class..
I'm getting 19-20 hwy keeping speed to 65mph's
Old 06-20-2008, 07:11 AM
The only things i really did to my truck were stuff to fix it. And im getting a ford cause the last fords i had were great and the last couple chevys i had have been nothing but crap. Im not that worried about gas mileage, 13, 14,15, ive seen it all with any truck ive had lately.
Old 06-29-2008, 08:58 PM
ukrkoz's Avatar
ukrkoz ukrkoz is offline
well, to be honest, most of this is regular maintenance. i bought mine with 58K miles on it and 1st thing i did was to replace ALL the fluids, which you don't even mention rear diff, front diff, and transfer case fluids. plugs too. wires too.
but yes, they are called clunkers for good reason. even better, chevy does squat to remedy persistant problems, same issues, like steering wheel clunk, run through generations of those trucks. make things worse, you got yourself underpowered 4.3L, and it has lots of weight to push around, thus crappy mileage and wears out much faster than 5.3 or 6.0 brethren.
what can i say. don't buy fords, period. you'll regret it even worse. if you just must have truck, and that's yours and yours only decision, save and get tundra or titan, and be blessed. you will not find hasppiness in domestics.
Old 06-30-2008, 08:19 AM
Ive just never had a car/truck that has needed more work on it at 55,000 miles than that silverado i had. Heck i had a '93 1500 with a 350 TBI, 5 spd. It was all original up the time i sold it at 130,000 miles in 2004. And i did have to replace front diff and rear diff fluid, plugs and wires, if i didnt mention them before on the silverado. And ive had a couple fords before and didnt have nearly the amount of problems that i have had with my last 3 chevys (Silverado, and two blazers) Thanks though.
Old 06-30-2008, 01:35 PM
Originally Posted by ukrkoz
i if you just must have truck, and that's yours and yours only decision, save and get tundra or titan, and be blessed. you will not find hasppiness in domestics.
do not buy toyota trucks.....check it out they have severe frame rot problems so you have been warned....
this was so bad that toyota gave the owners a very good deal if they purchased a new rust bucket....
