Go Back   Automotive Forums Car Chat > Mercury > Sable
Old 06-05-2008, 07:02 AM
sehnde sehnde is offline
A/C Problems
Hi, I live in Germany and I have problems with my Sabel A/C.
I have changed the compressor and fil up the system with 34OZ R134a. The compressor works few min. Because no cooling. The compressor stop the work after few min.
Is 34 OZ properly ?
in The top of the dryer is a conector. I have put a cable betwen both conectors and the compressor works few min mor. and now they dont work.
What can I do next?
Is ther everbody they speek German?
Best Regards from Germany
Old 06-14-2008, 01:25 PM
ruoffj ruoffj is offline
Re: A/C Problems
I have been having similar problems. I read somewhere that the a/c clutch cycling switch goes bad on Sables. My compressor wasn't running at all and when I jumped the switch with a piece of wire my compressor kicked on. The switch sits on top of the accumulator and it cycles the refridgerant through the system. I ordered the part but haven't received it, so I'm not positive that it will solve all my problems and I don't know if I'll have problems installing it. It sounds like you are having similar problems so it could be the same thing. I hope this helps you.
