Old 06-05-2008, 12:20 AM
Shered Shered is offline
1993 Chevy 5.0 no spark
I have a 1993 Chevy 1500 pickup truck . I had turned off the ignition and when I tried to restart it would turn over but not start. It is getting fuel but there is no spark. I changed the ignition pick-up coil and it started four times. I drove it for about 10 minute after that and turned the ignition off. When I tired to restart again there is no spark . Does anyone have a clue to what the problem could be.
THANKS
Old 06-05-2008, 08:11 AM
bigcoconut bigcoconut is offline
Re: 1993 Chevy 5.0 no spark
On my 92 the ignition control module went out on me. The little black piece under the distributor cap with two electrical connectors going to it. Pull the cap and change the ICM. When they wear out those things get hot and stop working and you have to let the engine cool down then they might start working again. This might be the problem with yours.
Go to the Rock Auto website and look up the AC/Delco part number D1943A for your 93 5.0 liter.
"Yes I have a truck and No I won't help you move your stuff..."
2008 Kawasaki KLR650 2500mi (fairweather commuter)
1992 C1500 Silverado 235,000mi (daily, not so much anymore, driver)
1999 Venture 120,000mi (moms vacation bus)
1989 Dodge Ramcharger SOLD, Yee-Freak'in-Haw
Old 06-05-2008, 09:19 AM
I took the ICM to Auto Zone had it checked and it was good. They ran a check on it several times to get it hot . It's like when , whatever gets hot it opens and then no spark. Will do some more checking today.
Old 06-05-2008, 10:17 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Replace it and be done with it.
MT
Old 06-05-2008, 11:30 AM
The auto guys at O'Reilly's told me the same thing except they said they could never get it as hot as the engine compartment can get it. They could check it to see if it works, but not at temperature.
Good luck, let us know what you find.
Old 06-05-2008, 12:18 PM
Ok I did some more checking and this is what I have come up with. I disconnected the ground batt. lead and let it set awhile after I connected it back up I had spark . It started and shut it off and tried to restart , no spark go thur the same thing disconnect the batt. , reconnect and spark. What would cause that?
Thanks
Old 06-05-2008, 01:11 PM
MT-2500's Avatar
AF - Advisor
Run the no start no spark test when it does it and find out.
Any codes or check engine lights.
Have you done the old pcm tap/twist test.
A bad pcm or dist module are sensitive to temp change.
If it is not a known good dist module replace it and see what it does.
MT
Old 06-06-2008, 03:21 PM
Ok I found a wire almost into repair and got a small spark . I went ahead and changed the ignition module even tho it checked good .It is now running .
Thank for all the feed back.
Great site .
Old 03-09-2009, 10:28 PM
87racer 87racer is offline
hi, i just got roped into a problem with a friends truck. 93 1500 , 5.7. he did the intake gaskets, now it wont start. when i got there, i pulled dist, checked tdc and ran all plugs and wires, fixed one suspect ground. still cold yellow spark and will pop some to try and start , but just wont go. any ideas would be appreciated...thanks
Old 03-10-2009, 09:38 AM
MT-2500's Avatar
AF - Advisor
To save on Hy jacking post.
Best to start your own New/Thread.
And someone will help you.
MT
Old 03-12-2009, 12:37 AM
sorry, i tried to find the icon to start my own post, am i blind or just getting old??? where is it?? thanks
