Go Back   Automotive Forums Car Chat > Buick > Century
Old 06-04-2008, 10:10 PM
sthole sthole is offline
05 fuel pump
i have an 05 century and have had the fuel pump replaced as it was giving a buzzing/humming noise under the driver feet. when i traced it back it was the fuel pump noise that was following the fuel lines up to the engine compartment. the dealer replaced the pump and the noise was gone for about 4 weeks. now the new pump does the same thing. anyone run across this issue and was the problem the pump or something else? thanks!
Old 06-05-2008, 11:52 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 05 fuel pump
Did you change the fuel filter when you changed the pump?
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 06-05-2008, 09:18 PM
Re: 05 fuel pump
yes i did. thanks,
Old 06-09-2008, 03:21 PM
richtazz's Avatar
Re: 05 fuel pump
It would be best to do a visual inspection of the lines to see if they are still in the frame brackets and not loose where they could hit the underside of the car.
