Old 06-04-2008, 06:39 PM
epssol epssol is offline
How to remove exterior rear tail light assembly 1994 LeSabre
I removed the clips on both ends of the assembly and the center screw. I also removed the license plate mounting screws. It does not seem to budge. Are they other fastners holding it. I want to remove some rust and repaint the bottom section of the assembly and need to remove the assembly to prep and paint.
Thanks
Old 06-04-2008, 07:34 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: How to remove exterior rear tail light assembly 1994 LeSabre
IIRC, studs are mounted on the taillight assembly and go through the trunk to the inside. Interior trim will need to be removed to expose them. The studs should have nuts on the back side that can be easily removed.
