Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 06-04-2008, 09:55 AM
JayrodEF JayrodEF is offline
Help with non-starting bonny please!
Hey all, my first post here. Hopefully you guys can help me out. I have a '92 bonny SE with about 145k on it. It had been hesitating under load for about 3 weeks. Then one day I went to start it and it just cranked, didn't start. I'm not getting spark off of any coil, and I'm not getting an injector pulse. I AM getting 12 volts at the injector and at the ICM pigtail. I've tried replacing the crankshafts sensor, the ICM and all three coils and it's still getting nothing. Any ideas on where I should look to next? There's no trouble codes present, the lights not on and I tried to scan it anyway and got nothing. Thanks in advance!
[EDIT]
Forgot to mention that I've also cleaned off all the corrosion between the mounting plate and the bracket and the ICM, applied dialectric grease to it and all that. I've also check to make sure that I get fuel squirting out of the FPR when I push the little schraeder valve in, the vaccuum hose attached to the FPR also does not have fuel in it, so I think that's ok.
