Old 03-06-2003, 05:54 PM
chevyfreak chevyfreak is offline
Dual exhuast
Hey all!! I have heard that installing dual exhaust on some cars if the second new pipe gets too close to the gas lines it will get it too hot and cause vapor lock by turning the fuel into gas.
I am considering put dual on my 96 Cavy and i want to know if anyone knows if it will effect it, or does anyone have dual after market exhaust on...and has it caused you any problems?????
Thanks in advance
Old 03-06-2003, 06:21 PM
tricky8 tricky8 is offline
turning the fuel into gas....................maybe you use a hybrid that only uses batteries and by fuel you mean battery acid...........im kidding with you but i think you mean catch the fuel/gas on fire, if thats the case i think it would be possible but i highly doubt it, but i would run the second exhaust along with the first and if you want one on each side of the car just run a pipe a foot away from the end of the car to the opposite direction and then go out, that is just what i personally would do
Tricky
Old 03-06-2003, 07:01 PM
actually thats not what i am talking about at all............its just gets the gas lines hot to where the ....gasoline actually heats up and turns from liquid to vapor causing a vapor lock. And as u prolly no a car cant run from vapor......
Old 03-06-2003, 07:06 PM
Shortbus Shortbus is offline
Blah blah blah
Send a message via AIM to Shortbus
If vapor lock became a problem you could use an exhuast pipe wrap or maybe even insulate the fuel lines.
Just an idea.
bolt on dual exhuast loscochinos520 Blazer 0 10-15-2005 04:21 PM
Dual exhuast RKelly2121 Mustang Talk 4 08-14-2005 03:51 PM
96 f-150 dual exhuast ? Devo2133 F Series 5 08-01-2005 01:10 PM
2003 Accord Coupe - Dual Exhuast on the I4? Defkkon Engineering/ Technical 10 08-14-2003 01:47 PM
Anyone Running Dual Exhuast on V6? Toy4x4Guy Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 16 03-15-2002 05:35 PM
