Old 06-04-2008, 12:38 AM
Donb1955 Donb1955 is offline
95 PA starting & sputtering problem
My 95 Park Ave will start for a second and die. Worse on cool mornings (below 60). it may take 1, 2 or 25 tries to keep running. Also coughs even under a light load accelerating. Mechanic said my mass air sensor alarmed. I just replaced it and exchanged my ignition module for a new one too. It seems to be better (more intermittent but still there). he also said my fuel pressure is 10 psi below min requirements. Don't want to change that out yet because of the hastle with removing the tank. Any ideas or experience in the matter. Long history of computer issues with this beast as well. Still like the Supercharger though!!!
Old 06-04-2008, 07:49 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 95 PA starting & sputtering problem
When was the last time the fuel filter was replaced? Has you mechanic checked the engine temp reading with a scanner when the engine is cold?
Old 06-11-2008, 09:20 AM
Sweepspear's Avatar
Sweepspear Sweepspear is offline
Wink Re: 95 PA starting & sputtering problem
I had that same problem with my '92 recently, and it was the coil pack.
Here is a link that shows how to test it if you hava a multi meter.
http://www.pontiacbonnevilleclub.com...hp?f=48&t=1683
Dale
Current Buicks..1996 Riviera. / 1992 Park Ave. /
1970 Riviera (2nd one)
Past Buicks. '66 Riviera / '70 Riviera / '90 Riviera / '72 Skylark / '72 LeSabre / '72 Electra / '96 LeSabre
