Go Back   Automotive Forums Car Chat > Chrysler > PT Cruiser | PT Cruiser Convertible
Old 06-03-2008, 09:12 PM
5151Christy 5151Christy is offline
P.T. Cruiser 2004
Have a Base Model P.T. Cruiser with auto trans.
The speedometer is making a lot of noise and acting up.
Is there some way to disconnect speedometer?????
Thanks for any and all replys
Old 11-03-2008, 02:33 AM
Towncar's Avatar
Towncar Towncar is offline
Re: P.T. Cruiser 2004
Hello 5151Christy - -
Are you quite sure it's the speedo making the noises? These are electronically controlled gauges with fluid dampers.
There is a test mode for this Cluster Assembly.. you might try to run the 'self diagnostic check' to see if that cures your ailments.. it will reset all the pointers during the checkup..
Have a look at the attached pages from the 2004 FSM, I've also attached the VSS section so you can have an idea how the Speedo gets its signals.
2004 PT, Cluster Operation and Diagnostics
2004 PT, Vehicle Speed Sensor Operation
-Steven
1996 Town Car, Cartier
