Old 06-03-2008, 09:21 AM
Ruby&Ray Ruby&Ray is offline
2002 windstar
I am looking for the correct socket to remove the nut on the front rotors in order to replace them???
Old 06-03-2008, 09:58 AM
12Ounce 12Ounce is offline
Re: 2002 windstar
Read message ... I don't think you want to remove that nut.
Old 06-03-2008, 10:16 AM
Re: 2002 windstar
i read you're first response..thank- u..so he does not have to remove that nut??..@ all...ford told him that he just had to hit the back side of the rotor..is that correct?...he bought replacement rotors..and has been trying to figure this out for 1 week yet...he has no clue..so i'm trying to help out
Old 06-03-2008, 12:05 PM
garync1 garync1 is offline
Re: 2002 windstar
Front rotors have factory torx head.. Not sure on the size torx bit needed but you will need one.. You do not have to use those bolts anymore.. Just take them out and throw them away.. The new rotor may not even come with those holes.. But there are torx bolts near the lug area that hold the rotor on when going down manufacture line when it was being built.. Torx head is like a star type head.. hope this helps..
Old 06-03-2008, 12:12 PM
Re: 2002 windstar
Of course, the moving half of the brake caliper has to come off also. Can be done easily ... the 2 slide-bolts. Or can be done the hard way ... the mounting bolts for the whole caliper. (Assuming your model is similar to my '99 ... which it may not be!)
Old 06-04-2008, 08:41 PM
wiswind wiswind is offline
Re: 2002 windstar
I have a series of pictures that show the front brake pad & rotor replacement process on my '96.
Take note that I am NOT a mechanic......but this should give you some guidance.
My rotors had been replaced before.....so I did not have the "torx" screws to hold them on (as mentioned....they are used ONLY on the OEM at the factory to aid in the assembly line process).
http://rides.webshots.com/photo/1327...11220610zyKeJn
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 06-05-2008, 09:26 AM
mundy5 mundy5 is offline
Re: 2002 windstar
the factory torx screw is a T-40 according to one of my receipts. it's not on there very tight at all. I bought the $4 bit and it turned quickly and had my OEM rotors turned and i was back in business.
2003 Windstar LX
1998 4dr Civic LX
