Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 06-03-2008, 01:25 AM
shadowtag88 shadowtag88 is offline
Monster in the exhaust manifold
I recently had a check engine light and got the error code for the O2 sensor bank one sensor one - on the exhaust manifold
i bought the new sensor today, changed it and in the process i made a discovery.
something had hit the o2 sensor that had gone bad from inside the exhaust manifold. what seemed to have hit it was a piece of metal that was in there SOLID. it appeared that when it hit the o2 sensor, it bent the threads on the exhaust manifold thereby making it EXTREMLY difficult to remove the original sensor. I had expected it would require a few good cranks and for it to come out smooth the rest of the way. instead it was a struggle the entire way out.
once the new one was ready to go back in, the threads on the manifold were slightly ripped up, we took another 02 sensor with good threads and ran that through hoping it woudl realign the threading..
we then took the new o2 sensor and began threading it on, the "piece of metal" in the manifold that we believe hit the old sensor was in the way of the new sensor getting in. we pushed that back a bit with a socket extender and once that was bent back a bit, the sensor went in much more easily. as for the threads, that was still a hassle and the threads were still striped slightly once the sensor was in.
SO-
is there anything that would be heat resistant as well as safe to put around the threading on the sensor to prevent a leak since its not 100% of the way in?
and more importantly, im curious as to what the hell is in the exhaust manifold/ ate my o2 sensor.
any help would be appreciated. thanks
Old 06-04-2008, 05:00 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Monster in the exhaust manifold
If you haven't tried it, run a tap through the threads. It may clean them out enough to insert the sensor all the way. That sensor may not work well if it is not all the way in.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 06-04-2008, 09:06 PM
we had thought to use a tap but the problem was...
first we didnt have a tap that was big enough and
second even if we did, the angle we would have to insert it would have been next to impossible. the only way to have done it halfway decently was to take the whole header off and that was too much of a pain to do.
for now the o2 sensor works fine. and thers no CEL. someone suggested locktite red stick?
Old 06-05-2008, 09:33 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Squirt some soapy water around the fitting when it's cold and start it up. If it bubbles or spits, then there's a leak.
I can't think of what might have come loose and lodged against the sensor. As long as it doesn't impede the exhaust flow then I'd say don't worry about it unless it breaks loose again and gets into the catalytic converter. I myself would be tempted to remove that piece of downpipe and try to remove the obstruction.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
