Old 06-02-2008, 11:42 PM
fixit01 fixit01 is offline
1997 grand voyager-major help needed please
Replace transmission speed sensor input side, transmission speed sensor output side. Still have the three prong connector vehicle speed sensor to replace but can't locate it under the hood. According to the auto parts store and a diagram I got free from http://www.oplin.org/databases/proxy...ain.autorefctr there ARE these three sensors on this tansmission I have- 1997 Grand Voyager 3.3L 6 cylinder. We can't locate it and it's driving me nuts!!! Please Help!!
The above link takes you to free auto repair manuals. Just click on the link, enter card number 123456789, click on the down arrow and select Public Library on Cincinnati adn Hamilton County, then click on submit. When the link is displayed scroll down to the Auto Repair Referance Center. You can take it from there.
If you know of any free sites with a diagram that can help my delima above please let me know.
Thanks!!
Old 06-03-2008, 02:23 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 1997 grand voyager-major help needed please
I'll guess and say you have the 41TE 4 speed transmission. Not sure which connector you mean but this may help. There's a diagram near the top and scroll to the bottom for another. Looks like you'll have to copy and paste the link.
acidtechno.freehost.pl/A604codes.pdf
EDIT
Looks like the link won't download the .pdf file so type "41TE transmission speed sensor location" in a search engine and look for this:
[PDF] Here are a few pictures of the A604/41TE Transaxle so you know where ...
221k - Adobe PDF - View as HTML
Likely Cause #1: The Output Shaft Speed Sensor went bad. ... Engine speed signal circuit. Note: Transmission controller is not ...
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 06-03-2008, 09:02 PM
Vats Vats is offline
The spees sensors are located on the front side of the tranny. You will have to remove the air box. Where you see the transmission cooling lines go into the transmission the sensors are located either side of the lines. The input is closest to the engine and the output closest to the fender.
