Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-02-2008, 09:24 PM
eclipse787 eclipse787 is offline
vss
are the veichle speed sensors the same for a manual transmission and an automatic? - i have a 420a with now an nv-t350
Old 06-02-2008, 09:37 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: vss
I doubt they are. Compare part numbers on the advance website and see.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 06-02-2008, 09:45 PM
Re: vss
yeah i looked at the autozone pictures and the automatics have an input and an output speend sensor plug. so theres two plugs, now i have to find where to put my three wires from the manual tranny speed sensor into these two plugs. any body done that before? anything will help
Old 06-03-2008, 03:56 PM
Holset powered 420a
Re: vss
Wait... So you have converted your 5spd into an auto?? The wiring harness is going to have to be changed for everything to work correctly.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 06-04-2008, 09:32 PM
ned032002's Avatar
ned032002 ned032002 is offline
Re: vss
you should be able to find some write ups on this conversion. do some searchin son!!
