Old 06-02-2008, 09:02 PM
tatters29 tatters29 is offline
Angry Shifting Issue or Interchange Trans
Hi all, I am new here so you may have answered this before but here goes .....
I have a 92 Caravan with trans issues. At first the trans would have problems being stuck in 2nd gear , shut off and restart a couple of times and it would shift fine, so i researched it and found the shift soleniod was bad, rattled when taken off and inspected. I replaced soleniod pack and it was shifting ok only issue next day was when driving down the road the trans would go into neutral. 2 weeks later still doing neutral while driving down road but not often. I drove 650 miles on a vacation trip and it went into neutral twice and on the return trip home a BUNCH of times. So while moving down the road I would put van in nuetral and shut off and restart while moving, place van back in drive and it would be fine. So I either need help with if its a switch or will my 1990 caravan trans ( that is fresh rebuild 3 months ago ) interchange with my 92?
Old 06-05-2008, 03:04 AM
Rawtorque Rawtorque is offline
Re: Shifting Issue or Interchange Trans
It would be best to see what's causing the problem with the current transmission. You will need to buy a scanner that will work. Some shops will scan for a small charge. It could be as simple as a ground wire problem.
Old 06-06-2008, 12:08 AM
hmmmm when going over train tracks today the dang thing did the second gear only again ..... do you have any previous experience with the wiring issue as to a common area the ground fault is at ??? like 90-92 tempos had a problem with wiring shorting out altenators. I bought a BUNCH of these cars then cheap cuz if you lifted the radiators you would find a pinched wire. got any ideas where to start looking????
Old 06-06-2008, 03:00 AM
Well, you can try this:
http://www.robskorner.org/faqs/Trans/a604intlimpin.html
I just wish it said what size drill bit to use. It sure sounds electrical, unless the fluid is low.
Old 06-11-2008, 11:01 PM
thanks
