Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 06-02-2008, 02:03 PM
purpmane purpmane is offline
Headlight trim/bezel help
Hi. I'm new here and need help. I recently purchased a replacement passenger side headlight bezel and side marker for my 88 Caprice. I cant figure out how to remove the headlight and trim to replace it with the new. Can someone please help? I already have a star screwdriver to use. Thanks in advance.
Old 06-02-2008, 03:06 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Headlight trim/bezel help
You have to remove the headlamp assembly - there are three bolts on the rear of the header panel to remove. You should be able to reach these from under the hood, no problem. You will need a 10mm socket. If it's the passenger side, you will have to remove the battery. Once you have the lamp off, there are 4 Torx style screws that hold the bezel in place. I believe these are T15 but might be T20 size.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
