Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 06-01-2008, 11:26 PM
89rscamaro 89rscamaro is offline
700r4
Are there any 700r4 transmissions that don't have the lockup torque converter and aren't computer controlled. Thanks for the help.
Old 06-02-2008, 08:11 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
Re: 700r4
There are ways to use a 700R4 transmission without a computer if that's what you're looking for.
Bob
Old 06-02-2008, 10:41 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: 700r4
To answer your question, the 700R4 _requires_ a lockup converter - all of them do - if you do not use lockup, you risk frying the 3-4 clutch. Also, only the 4L60E variant required a computer - all other 700R4 or 4L60 transmissions are hydraulic. Check for the presence of a TV cable - if you find one, you have the right transmission.
You can replace a pressure switch inside the transmission for the lockup, then all you have to do is run an ignition-on power source (and ground) to it. The transmission will take care of the lockup function automatically.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 06-02-2008, 11:37 AM
Re: 700r4
are there any ways to hookup a 700r4 lockup converter without opening up the trans. thiniking of putting one in a 59 chevy biscayne for better mileage.
Old 06-02-2008, 07:05 PM
silicon212's Avatar
Confoundingly Lucid
Re: 700r4
Short of using a computer to control the lockup, no. It's not a difficult thing to take the pan off and replace the pressure switch. You need an oil sending unit socket, a 1/2" (or 13mm) socket, ratchet, extension and some oil (4 qts trans oil), plus the switch and reconfigured wiring harness. It's about 30 minutes worth of work.
Old 06-03-2008, 12:07 AM
Re: 700r4
where do i get the pressure switch.
Old 06-11-2008, 11:53 PM
Re: 700r4
where do i hook the tv cable to and what pressure switch do i need to put in the transmission thanks for the help
Old 06-12-2008, 12:20 AM
silicon212's Avatar
Confoundingly Lucid
Re: 700r4
Go to www.bowtieoverdrives.com and indulge. There's a LOT to learn about the TV system, if you want the transmission to survive.
Old 06-19-2008, 02:19 PM
comp comp is offline
Re: 700r4
isn't there a company the make's a Non-Lock convertor for 700's ??
