Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 06-01-2008, 08:14 PM
criticerz criticerz is offline
Time to fix it
So I'm in need of a car now and I need to fix my stepdad's 1988 Caprice. I hope you guys can help me out. My mom crashed the front into a truck and it got kind of messed up. :P
Anyways, you think you guys can help me find the parts that I need to buy with these pictures? I know it's hard because they are pictures, but name the ones you see, please.
Thanks, Alain
Old 06-01-2008, 08:24 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Time to fix it
Looks like new header panel and grille time. Check the radiator support behind to see if it's damaged, doesn't look like it might be though. You haven't shown the hood so I don't know if you need one of those.
At any rate, it appears from your photos to be cosmetic, superficial damage.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 06-01-2008, 08:33 PM
deesandvees's Avatar
deesandvees deesandvees is offline
Re: Time to fix it
Looks like you just need the header panel. Not sure if the radiator support was damaged or not but if it was then you'll need that too and maybe a radiator if it's messed up. Headlights look good which is a plus because it's easier to find a header panel without headlights sometimes. People take the headlights out and sell them because new they're somewhere around $100. Any header panel from 87-90 will do just fine.
That's what I'm talking about but I recommend checking your local junkyards. You should be able to find a 87-90 Caprice no problem usually and you can get the whole peice you need. It's real easy to remove and install. Can't remember exactly but maybe 5 bolts each side for top corner of fender and a few bolts each side to the radiator support. Just unplug all the lights from up there and it's not even that heavy either.
'87 Landau
Old 06-01-2008, 08:42 PM
Re: Time to fix it
Perfect. Thank you very much guys. I'll come back if I need more help.
Old 06-01-2008, 08:51 PM
Re: Time to fix it
Quick question:
http://www2.partstrain.com/store/ind...257+2349&Nty=1
Can you guys tell me which radiator from there is ok to put on the car... I don't want to spend too much, but I don't want it to be crappy either.
Old 06-01-2008, 10:36 PM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
Re: Time to fix it
Don't forget, the A/C condensor is in front of the radiator, and is more than likely shot. If you want A/C, that's gonna need to be replaced as well.
Old 06-01-2008, 10:37 PM
silicon212's Avatar
Confoundingly Lucid
Re: Time to fix it
Originally Posted by criticerz
Quick question:
I would go for this one: SILLA2044-3
Old 06-01-2008, 10:47 PM
Re: Time to fix it
Ok thanks. Anything else? Also, do you see that metal thing going around the headlight on the last picture... where can I find that?
Old 06-01-2008, 11:02 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: Time to fix it
Those should also be available at a salvage yard. They are called 'headlight bezels'. From the pictures in your first post it also appears you need to replace the rubber/polyurethane filler panel between the header panel and the front bumper.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 06-01-2008, 11:04 PM
Re: Time to fix it
All that will be attached more than likely if you find one at the junkyard.
'87 Landau
Old 06-01-2008, 11:09 PM
Re: Time to fix it
Alright. Thanks everyone. Let's hope I find everything when I go.
Old 06-01-2008, 11:10 PM
Re: Time to fix it
And once it's fixed, before you let your mom drive it again put one of these pushbar's on
thanks to Silicon's page for the pic
'87 Landau
Old 06-01-2008, 11:26 PM
Re: Time to fix it
Haha... Yeah right. I don't even like the ones I have on right now, imagine those.
Old 06-02-2008, 12:09 AM
silicon212's Avatar
Confoundingly Lucid
Re: Time to fix it
ROFLMAO!
As an aside, from looking at the pic of my car there (Thanks Dees!), I have to let you in on one thing. Niether the hood, the header panel, the bumper nor the driver fender are original to the car. The hood and fender came from an '81 Impala, the bumper from an '84 Caprice and the header panel (complete with lights, filler strip, grille, bezels you get the point) from another '88. All because I T-boned a '90 Accord at 30MPH, causing him to go airborne and land on the hood, taking out the above mentioned items. The total cost of replacement parts? $275.
The pushbumpers didn't get hurt (as you can see), but one got ripped off the bumper (which remained straight but had torn metal on the top). I reused them.
The Honda was undriveable. All my car got was a black eye.
Old 06-02-2008, 11:55 AM
Re: Time to fix it
Whoa Silicon, makes me think a little more about getting one of those. I'd rather be caught with than without.
'87 Landau
