1999 Exp EB miss/hesitation at 40-50mph
My expedition misses only when driving around 40 or 50 mph. The vehicle vibrates or shakes then if I stomp the gas it goes away. I replaced the spark plugs before this happened. I used Autolite Platinum plugs. Anyone have this same problem? Do you think it can be the plugs are bad and I should replace them with Motorcraft plugs?
Thanks |
Re: 1999 Exp EB miss/hesitation at 40-50mph
Does the "miss" occur right at shift point into high gear? If so, it is more than likely torque converter shudder. Let us know.
Being way2old is why I need help from younger minds The sooner you fall behind the more time you'll have to catch up. ![]() HEY Y'ALL--READ THIS Here are some of our old vehicles for sale.
When I take off you feel a slight miss from take off, real light. As I go faster it the miss is there. Only when going around 40 - 50 mph is when the truck hesitates hard or shakes. I hope this describes it a little better. Thanks for the response.
Have you checked for any DTCs - Diagnostic Trouble Codes?
Even if your Check Engine Light is not on, you may have a code in the computer. BTW, what size is your engine? Autozone will provide a check on your OBDII system for you. If you do not have a code scanner. Autolite plugs are the same as Motorcraft. Just make sure they are double platinums. I could also be tranny related too, but check for codes in the mean time.
1999 Taurus 1995 Windstar 1996 Bronco 2005 Escape 2002 F150 2007 Explorer |
I d put some motorcraft plugs in it. Ford engines are sensitive in relation to ignition parts. Make sure they re gapped within specs.
I got a engine code to come on tonight. I will have it checked tomorrow. I'll also update tomorrow. Thanks for the replies.
The code was a 301. I checked the coil and it was bad. Replaced it and now the truck runs smooth. Thanks for all the help and replies.
