Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 06-01-2008, 04:45 PM
orange57 orange57 is offline
Subframe removal
I'm in the middle of removing the transmission from my 1989 oldsmobile 98, and it calls for the removal of the subframe. once removed, and the transmisson is out, can i set the car back on the front wheels?
Thanks,
Old 06-06-2008, 09:39 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Subframe removal
No, not without an engine support. Most trans shops remove the drivers side frame support bolts and loosen the passenger side bolts enough to remove the transaxle without removing the whole subframe.
Old 06-06-2008, 11:08 PM
i have an engine support bar that i'm using to support the engine. The procedure according to my haynes manual is to remove the subframe. after i pull the trans, i would like to set the car back on the wheels, and support it from underneath so i can close the hood and not have it sitting in my driveway with the hood up.
Old 06-19-2008, 09:35 AM
Jrs3800 Jrs3800 is offline
IIRC, this car will have a separable Frame... Look at the front Passenger side of the frame, you should see a few bolts holding it together at the corner.. You should not have to remove the Passenger side of the frame or the Main frame to body bolts...
You should support the engine tho and have a way to get the trans onto the ground...
