Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 03-06-2003, 02:23 PM
Bimmi96 Bimmi96 is offline
Question My 96 BMW 316i wonīt start
After washing my car it would not start. The starter is ok, and the switch seems to be normal. I'm thinking it is some sort of sensor but I canīt figure it out. Is there anyone that has a clue?
Old 03-06-2003, 05:42 PM
tricky8 tricky8 is offline
be more specific with what its doing, if its cranking over, if you got lights inside the car such as check engine, if its cranking over it can be a fuel problem, if you dont got lights it can be a simple dead battery, just a few things that may be wrong but without being more specific you cant really say anything and its even harder not having it here to be able to listen to what its doing but hopefully for you theres no lights and the battery is dead.
Tricky
Old 03-16-2003, 05:39 AM
alibrownbmw alibrownbmw is offline
Non-Start
Hi there!
A common problem with non starting E36's is that water gets into their DME control unit.This is located next to the fuse box. You'll know it when you see it, the unit with the biggest wiring plug on it. Disconnect your battery, remove the control unit. Remove it's cover and see if it's wet, (try not to touch any of the components)If it is, dry it out in a warm place. Replace the cover,reconnect the wiring (if you wish you can place it in a waterproof bag and cable tie the top), reconnect the battery and hope for the best!! This is only one possible cause, but worth a try considering it only happened after you washed your car.
Hope this helps
ali
Old 04-11-2003, 09:07 AM
m5runner m5runner is offline
Send a message via Yahoo to m5runner
heard and seen that story a million times. i have good news for you though. i repair BMW DME's for a living. for the most part i repair them for $100 plus S+H. A new one from BMW will run you over a grand so think about it. [email protected]
Old 04-11-2003, 09:30 AM
kaoru-tochiro's Avatar
kaoru-tochiro kaoru-tochiro is offline
Banned
BMW installed the DME's outside the cabin so they would get whet and make unsuspecting drivers constantly buy new ones. I think that company has been bought by Ford.
Old 04-11-2003, 09:50 AM
i might be wrong but motronics makes BMW brain boxes. looking at one now as we speak for a 750IL.
Old 04-11-2003, 10:19 AM
Banned
Motronics, is that by BOSCH? and why did they stick the computer otside instead of in the cabin like they did in the 80s?
Old 04-11-2003, 10:59 AM
yup. motronics is a BOSCH thing. my puter is located right where the battery would be. either way, a car wash, heavy rain, forgetting to put the ground wire on the thermostat housing can cause damage to the box.
Old 04-11-2003, 12:42 PM
Banned
I have a 1984 e28 and its computer is nice and toasty and dry in the glovebox I can't understand why they would put it in the engine bay?
I guess they wanted to give passengers more glove space.
BMW 316i Radiator Problems Good Ride 3 Series 1 08-29-2007 10:03 AM
BMW 316i compact progress Slo_Snipe WIP - Street 42 06-21-2005 01:23 AM
BMW 316i audio wiring kenisu 3 Series 2 08-11-2004 08:24 PM
BMW 316i finished pics. Valentino WIP - Street 10 07-19-2003 02:02 PM
I just bought a 1990 BMW 316i..Need info Spencer 3 Series 1 05-19-2002 01:01 PM
