Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-01-2008, 11:45 AM
thisismylife thisismylife is offline
1991 camaro wont start
GA_googleFillSlot("Forums_ROS_300x250_noad");I have a 1991 camaro rs with the 3.1 I was driving it and when I would come to a stop it would die then I would put it in park and start it back up well It wont start back up any one know what the problem is thank
Old 06-01-2008, 11:33 PM
89rscamaro 89rscamaro is offline
Re: 1991 camaro wont start
need more info
Old 06-02-2008, 08:42 AM
chevyrulespops's Avatar
chevyrulespops chevyrulespops is offline
I would try to check for an engine code....the computer might have stored the fault which might lead you in the right direction....do you have cranking or nothing at all? Are your instrument cluster illuminating?
Old 06-02-2008, 09:36 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
definately need more info. does it crank and not start? does it not crank at all? check for spark and fuel then get back to us.
Old 06-07-2008, 03:38 PM
it would not crank at all it was turn the key and nothing would happing i fix that the starter was bad and froz and not alow it to spin the onlything that dont work is my rpm gage thanks
