| Search | Car Forums | Gallery | Articles | Helper | Quality Dog Food | IgorSushko.com | Corporate |
| Latest | 0 Rplys |
Show Printable Version | Email this Page |
#1 | |
Water bypass tube part number
Hello all,
my 01 SEL sprang a leak yesterday and I found the "water bypass tube and hose assembly" had developed a small hole in the 90 deg joint. Its the black tube that runs under the intake and has a press fit O-ring to seal it. Ive seen some threads about putting JB weld or even soldering the hole, but I figured I might just inquire on a new one. When I run the part number through every resource I have (im overseas so it'll be monday night before i can call a stateside dealership) the number that is actually stamped on the part shows no mathches. Has there been a change to numbers that I didnt hear about?? The number on the part is XF2E-8548-AB. Ive tried with and without dashes. Any ideas? |
#2 | ||
Re: Water bypass tube part number
on april 16 was $47.55 plus shipping. If you enter this number it will work. here is their web site: http://www.newfordparts.com/ |
#3 | |
Try this part #:F4DZ8A582A, at www:discountfordpartsaty2kford.com. Their website price is $13.50 plus shipping. They are located in Burien, WA. 206-431-7331. Hope it helps.
#4 |
#5 | |
jammer, i'd be extra careful and double check that you are ordering the correct part even if it means taking a trip down to a ford dealer and asking the parts guy while pointing visually at the hose.
2003 Windstar LX 1998 4dr Civic LX |
#6 | |
You are right 120unce, the top one is the one that is attached to the water pump and the other one goes under the intake.
#7 | |
Thanks everyone! I did just that, pulled it off and took it down to the dealership. Parts guy was very helpful. He mentioned that they sell a lot of them because people dont maintain the coolant like they should (drain and flush). Lesson learned? Maintain fluids like they should be!
Thanks again |
#8 | |
![]() Join Date: Nov 2004
Guess thats why my tube is still good.. ohhhhhhhh I Better knock on wood.
#9 | |
I don't believe in draining and refilling ... but I do believe in checking the coolant about twice a year to make sure its rich in anti-freeze ... about 60% ... and at least once in early life of car, I pour in a can of "water pump lube and rust preventative".
I've never yet replaced those tubes either (230 kmiles), but seems like good insurance to have them on hand. |
#10 | |
About every six months I just dump a new gallon of antifreeze coolant in.. I just drain the tank mainly.. If you do that when a car is new you want ever have to change it.. Same with brake fluid.. I vac pump my brake fluid out like that to.. Need to do my Power steering now I already change it 2 yrs back..
#11 | ||
