Old 05-31-2008, 06:41 PM
prizefighter prizefighter is offline
climate control problem
I'm not getting any forced air through the vents regardless of if it's heat or air conditioner. All vents are open, the fan seems to work normally and at different speeds and the rear vents don't get forced air either. The vehicle will get cool or warm eventually...just through the normal motion of air I suppose.
In searching these forums, I didn't seem to get a good idea and my particular issue so I'm asking here.
I have had to remove the cowl before when changing spark plugs before...could I have done something there? Is that where I'm going to have to go to solve this? It seems like it should be something easy.
Old 05-31-2008, 07:37 PM
wiswind wiswind is offline
Re: climate control problem
Where the air goes is driven by vaccum actuators.
If you loose vaccum to the actuators......then the default position is defrost.
It is likely that you bumped one of the vaccum lines for this.....A line goes from the back of the upper intake manifold to a resivoir near the passenger side strut top in the engine compartment....mounted onto the inner fender.....and a line goes to the firewall to get the vaccum into the passenger compartment.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 05-31-2008, 07:52 PM
mundy5 mundy5 is offline
if your symptoms are similar to this thread, I have the pdf that I can send to you. If you are handy and willing to follow schematics, then you are welcome to it. Just read the thread and pm me your email add and I'll attach it.
2003 Windstar LX
1998 4dr Civic LX
Old 06-06-2008, 08:45 AM
veerg veerg is offline
mundy5,
I am having the same problem. I am getting air through the defrost only. Could you please send me the pdf document....I have just emailed a msg to you...thanks.
Anyone else has any suggestions where to look ?
Old 07-03-2008, 05:13 PM
bobinkski bobinkski is offline
I am having same vaccum problem. Wiswind I looked at your webshots to find the actuator, hard to see.I found the 2 vac. lines entering the black actuator. Now can I replace the actuator or the switch on the control. There are 6 different vac. lines coming off the switch, all seem to be in good condition. To check for vac leak under the hood, hard to hear anything with the car running. Has anyone replaced the actuator and fix the problem. Also, first I should mention that turning the vent or AC on the air blows out the defrost for about 20 seconds and the through the vents. Seems to be a slow vac. leak. I can watch the valves under buy the gas pedal move from defrost to vent. I hear no hissing. Anyone, Wiswind can help me please. Thanks. bobinkski
Old 07-03-2008, 05:19 PM
check this thread out:
http://www.automotiveforums.com/vbul...d.php?t=905284
if you want a pdf, pm me with your email add.
veerg, did I ever send you that pdf? I have no record of your pm...
2003 Windstar LX
1998 4dr Civic LX
Old 07-03-2008, 05:55 PM
mundy5, I checked out the theard seems no help. The control switch has 6 vac. lines, yellow,blue,orange,black,green,red. I only get vac. on the black line. There is red and black coming throuh the fire wall, there is red and black on the actuator. I believe the black from the actuator is for the intake. My email is [email protected]
Old 07-03-2008, 10:24 PM
just sent you the files. hope it helps.
2003 Windstar LX
1998 4dr Civic LX
Old 07-04-2008, 05:48 AM
tripletdaddy tripletdaddy is offline
For whatever reason, your defrost door motor is sluggish.
If you disconneted the door from the motor, does it move easily?
Are you getting enough vacuum, starting at the motor, at the controls output, then the black supply to the controls, then underhood at the vacuum reservoir, the check valve tee, etc. You will need a vacuum gauge to do this.
If you are confident you have a free door and good vacuum, then the motor sounds to be bad. If you have a vacuum pump, you could try seeing if you get it to move better.
Low vacuum at the black line to the controls, sounds like a blockage at the vacuum reservoir, tee check valve or further upstream.
Why don't you see if the other vacuum driven motors are also equally sluggish at start up. The one that I find easiest to verify, is the recirculating air door that is used only for MAX AC and when the control knob is set to OFF. When you switch in and out of MAX AC or OFF, you should be able to hear it move and clunk close. You may be able to see it move under the glove box.
Old 07-04-2008, 09:18 AM
tripletdaddy, it seems that 20 to 30 seconds the air goes from defrost to vent. I removed the vac. line connector from the control switch and got vacuum from the black line. All motors seem to be OK. You may be rigth that it up stream. Now I know where the check valve and tee are, but where is the vac. reservoir?,is that the same as the actuator wiswind mention? is the reservoir connected to the tee back by the fire wall? I do not have a vacuum pump,I know auto part stores have them. Thanks for thr reply, bobinkski.
Old 07-04-2008, 02:19 PM
garync1 garync1 is offline
I would replace the check valve while you are in the area.. Cheap part and also rules it out.. Camero check valves go out a l lot. Easy to replace though.. On the Camero that is..
Old 07-04-2008, 06:34 PM
What I did today is I was looking at the motors (that is the 2 vac. lines hooked up to it and moves the door) took off the vac. lines, moved the motor, then took off the vac lines at the switch and blew through them and then alittle sucking on them and now the system works. Go figure? I Think dirt in the line some where, I don't think I'm out of the woods yet. I still need to now where the vacuum reservoir is at. I am thinking of removing the cowl and check the lines and replace some items.
Old 07-05-2008, 02:14 AM
The actuators, wiswind spoke of are the same as the vac motors that move the doors. He also staed where the reservoir is under the cowl behind the passenger side strut tower. I think it is black, but a real pita to get to. I'm not sure accessing it will have any benefit as you are getting vacuum. I think one way to see if it is ok, is to let it sit for awhile or even over night and see if there is any vacuum left by shifting the controls around to see if you can here and see the actuators still working. If not, then it is suspect. If not, you've saved yourself a bund of wasted time getting to it. If I'm right, the reservoir has a rubber like bladder or diaphram inside of it that moves with the amount of vacuum inside like a spring being stretched to help maintain nearly the same level of vacuum as it gets used up. Changing the tee check valve is a very good idea before diving in for the reservoir. If you have compressed air or just blow in it, Id try blowing in the vac lines in both direction through the firewall to remove any obstructions. DON'T BLOW ALL THE WAY TO THE INTAKE MANIFOLD!!! Disconnect the vac line at or before the manifold. You don't want to get any junk into your engine!
If you can get your hands on a straight, smooth tipped needle syringe, you can use it to create pressure and vacuum in the line and on anything else. I'd also be sure the vacuum controls for temp and air direction are not plugged up. There SHOULD NOT have been ANYTHING in your vac lines. It concerns me where it come from as this could be a perpetual problem if not fixed. Maybe not a big deal.
There are nice vac diagrams by Autozone.com here that you click on.
http://www.autozone.com/addVehicleId...00c152800ae23b
showing the two double acting and the one single acting motors. The defrost and heat door actuator, and the vent and defrost/heat door actuator each use two vac lines. The outside and inside air door actuator uses just one vac line. Air temp is controlled by an electrical motor/actuator gear drive keyed onto a door that diverts air away or through the heater core, which remains hot all the time.
Keep us posted!
Old 07-07-2008, 02:54 PM
So far the vacuum is still working. I have been turning it on and off alot and no problem. Ford doe's not have the check valve, told me obsolete part. Autozone has one, looks the same as Fords. Autozone part #47150, two way check valve. Would this work? I still like to clean out the entire line with compressed air.
Old 07-09-2008, 11:06 AM
Today the system is acting up. The vent takes 5-10 seconds to turn on.Under the dash took off vacuum line and then turned on vent, good vacuum right away, no delay. Hooked it back to actuator, and turn on vent. There is a delay in moving the vent door.I think now it is the acuator,Ford parts guy said they sell alot??? Ford cost $55 Rockauto $14.38.
