Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 05-31-2008, 03:33 PM
fred and mimi fred and mimi is offline
98 starting problems
Help! My daughter's 98 neon is hard to start on the initial startup. Changed the plugs, cap wires, air filter etc. Even ran lucas injector cleaner. No codes come up on a 55, which is end of cycle, I believe. Any one got any suggestions.
Old 05-31-2008, 04:35 PM
drifttruck99 drifttruck99 is offline
Re: 98 starting problems
My guess would be check your fuel system. Look for leaks after its been running for a little bit, if you dont see any leaks check your fuel filter
Old 06-01-2008, 03:54 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Are your battery connections clean and free or corrosion? Also make sure they are tightened down really well.
2003 Dodge SRT-4
Old 06-01-2008, 04:35 PM
Don,t think it's electrical. New battery, clean connections. Turns over fine. Just seems to have a problem getting fuel on the initial start of the day! Haven't check the fuel pressure yet. After the first start, it runs like brand new. Go figure!!! Thanks for the response!!
Old 06-01-2008, 04:38 PM
No leaks that I can see. Filter is part of pump assy in that year. Hope it's not the pump. Need to check fuel at the throttle body.
