Go Back   Automotive Forums Car Chat > Chevrolet > Blazer > Interior | Exterior | Appearance
Interior | Exterior | Appearance The place for all interior, exterior and general non-performance modifications.
Old 05-31-2008, 09:49 AM
kwk39018's Avatar
kwk39018 kwk39018 is offline
power wire
Were are you guys running the power wire though the fire wall on a 98?
It might a pos, but its my pos.
Old 06-03-2008, 08:10 PM
kwk39018's Avatar
Re: power wire
Well i guess i am the only one putting a stereo in a s series truck.
Old 06-04-2008, 07:47 AM
mixin mixin is offline
Re: power wire
You did not state what gauge wire you are running through, but if it is 4 gauge or smaller there is a good spot on the drivers side. The easiest on my 96 blazer was a factory grommet for a small wire harness under the carpet directly in front of the brake pedal. Simply pull grommet out, install slit with razor (careful of your digits and existing wire harness), run new wire through slit and re-install grommet. Worked for me, hope you truck is the same way!
Old 06-04-2008, 02:56 PM
kwk39018's Avatar
Re: power wire
Thanks, I am using a 4 gauge wire.
Old 06-16-2008, 04:10 PM
sickcallawayc12's Avatar
sickcallawayc12 sickcallawayc12 is offline
Re: power wire
There is a place on the passenger side by the glove compartment and may be easier since the battery is on that side also. You're basically using the same routing used for the factory radio antenna, i've never been able to locate this myself yet.
1998 Chevrolet Blazer LT (95% stock)
Pioneer AVH-P7500 DVD receiver
12" Alpine Type-R in a sealed box
PIAA Super Plasmas GT-X bulbs
PIAA Xtreme White bulbs
K & N drop-in filter
"Melo" and "AI". Enough said.
