Charging A/C
Hey all. I called a local auto parts store the other day about the A/C on my Rodeo. He said that it sounds as if I just needed to charge it. I was wondering.....Which one is the low pressure connector? Thanks.
Tony Ps. Just in case you need it. It is a 2001 with a v-6. |
Re: Charging A/C
Usually there are caps on them marked "L" and "H". Also, you shouldn't be able to even connect to the high side with a Wal-mart charging kit as the valves are different sizes.
If you're system is low on freon charge, you have a leak somewhere. Freon is not consumed like gasoline. If you never have a leak, you will never need freon. So, buy the stuff that has the leak sealer in it. |
