| F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
94 camaro v6 rough idle
I have a 94 camaro with a 3.4 and it has an extremely rough idle. I am thinking that its in the egr valve but im not sure. I recently changed the plugs and wires and it got a little better. But it is still very rough, just to add the car has 180000 miles on it.
Re: 94 camaro v6 rough idle
Ok the code that its giving me is an egr code, i havent read the code in a while. Other things that i had done to teh car was changed the alternator. Then changed the serp. belt, after that the water pump started to leak so i replaced that and when i got everything off the timing chain was pretty worn so i replaced that as well. I took the egr off and tried to clean it out a little bit but im not sure what i was doing so i didnt want to mess anything up
Im assuming you have a digital egr valve correct? I would replace it...if its staying open that would definitely cause a rough idle and even make the car shut off
